Alnternator Not Charging issue
Hello, I have a 92 SC300, when I bought the car alternator was bad. Took it in they said bad alternator. Bought a brand new alternator, but still not charging.
I have checked: the 120amp mega fuse, changed the alternator plug, no corrosion’s, battery is in perfect working condition as I checked with two batteries. When running battery reads under the 12v (11.25)
Am I missing something here? At this point I’m at a loss. Any advice, I would really appreciate it. Thanks in advance.
I’ll check to see if I’m getting the same volts on the power cable of the alternator to the battery, to see if they match when I get a chance. I’m stumped.
After all the checks, I decided to take off the brand new alternator and test it at autozone.
results...FAIL. Turns out it was the alternator after all, jimminy crickets!
![Rock On](https://www.clublexus.com/forums/images/smilies/rockon.gif)
