Replacement Wiper Blades
Just thought I share this here,
I'm not sure if there's any modern Lexus models that uses 20" and 21" blades stock, but after going through the Toyota spreadsheet of wiper blades I've discovered that current Tacoma models do use 20" and 21" blades (technically they are 19 3/4 AND 20 3/4)
BLADE:
RH: 85222-04040 (~$20)
LH: 85222-04040 (~$25)
Rubber Inserts: (~$10/ea)
RH: 85214-0E140
LH: 85214-0T040
the replace-ability of these rubber inserts make them better than most on the market and cheaper.
![](https://lh3.googleusercontent.com/SxuqGgqq__FJmjqAxA64AZ0mPHAwAq0ecihUKsxftdKUBrztir7UY6Qrv8emooxw7Y6qq7ZNmjf6uTOxvVg6-dAyfTFwQbfTwRcrsdLnwwT-sokeXZPDMHe4mg_RkzJkDcOCZf43HiNsQjdYZm2S9BwuPiIx8lwfRzkSSdv6lIWIJ9f803yZnMWjzIV83_Bz4dXaMAaG9mPSXUOKKUWmwlUSXPj3oJaiBbKwvE6kfYVb4fpARfWfvVpXORBDp87y-Z3nq4iZn6n21HCX9fnjd72uoPr_xHZrLOYrCBNHeSZOvwXYX5tFYxKVaJNRslZ-CBpk8aTsPdWC-oe-uAC3kVl37aX8siTlx97Jy0KMcyRSwFRrPnhoNeuAzse7wVC0P6WsZpagdfgy1G7QMsvegA2aab8zhML5LP7ZUuhAYVNXbd6AdZ6-4nmkA7wzVWndZwQLiENbcLtCm5KlFDBld-7n7Af6kiw787d8QQi_b8I120P5EnMhqCY4qQmKWPpvR-0RPYjLYBcvrS-rxE9iRplyq9FabO_hX4E2T1o3_-XNglmHBHYddzIhbvRFtnEjkBMcn_bI7HNhice7se-Gw0OwohaGCVFVofM59pHN=w1730-h975-no)
BLADE:
RH: 85214-0E140
LH: 85214-0T040
Good addition to these options:
https://www.clublexus.com/forums/sc-...e-upgrade.html
(Might as well have stuff cross-linked for future reference.)
