Horn Loss in the 2jz-GTE swap?
After some research I found that you aparently lose the horn function of the SC300 when coverting to the 2jz-gte motor is this true.....as far as I can tell I see that my horn connector is on the lexus wiring loom and not the supra wiring loom. Does anybody know how make the stock horn on the lexus work by spicing certain wires of paticualr conectors to the supra loom or something to that degree......for example the horn connector on the lexus wiring loom has a black/red and white wire running to it. Where do I spice these wires on the Supra wiring loom. Any help would be greatly appreciated. Thanks
Sincerely,
Adriel
Sincerely,
Adriel
There is a member on this board who sells conversion wiring manuals, I`m sure your question would be included in his manual as well as many other details you might need to know about while doing the conversion.
Thanks for the info Clint.....I was just woried cause after looking through phil's manual and and the supra manuals I noticed that the surpa horn went through a totally different path of connectors that are not described in Phil's manual. At any rate thanks
Sincerely,
Adriel
Sincerely,
Adriel
vntperform
Performance & Maintenance
28
01-29-13 07:46 PM
GTEgs300
10-18-08 08:10 PM
