O2 Simulator
Old 07-14-03, 11:11 AM
VSsc400
VSsc400's Avatar
more insights into o2 sensors and simulators.
I called summitracing and asked them.
They said to never use o2 simulators on o2 sensors on the headders since those are the ones that monitor the A/F ratio. Removing the o2 sensor on the manifold makes your car run richest of the settings read from MAF/temp/rpm/throttle/speed
The o2 sensors after the cat you can use o2 simulators since they only monitor the performance of the cats(makes sure cats are ok) and may or may not trigger check engine light on OBDI vehicles depending on which vehicle but did not have specific info on our vehicle.
The after cat o2 sensors deliver signal to your ECU in cycles every few seconds thus eliminating the check engine light(on OBDII).
Old 03-09-04, 09:38 AM
scsrock
scsrock's Avatar
Default Main O2 sensors?
Where do main O2 sensors locate? Could anyone show me where and how to get them?
Old 03-09-04, 10:05 AM
aliga
Former Sponsor
aliga's Avatar
main sensors are on the manifolds.
Old 03-09-04, 02:53 PM
scsrock
scsrock's Avatar
Post Main O2 sensors?
Thanks Aliga! ... i know these are car 101 questions, but seriously, i don't know
Where is the manifolds? Do you have to open it to get the main O2 sensors? (any special tools?) How do the main O2 sensors look like? How should they be handled? Any cautions?
I would be glad to hear anything that you like to share. I like to be able to get and see the main O2 sensors.
Thank much!
Old 03-16-04, 03:13 PM
JBrady
JBrady's Avatar
As VSsc400 says... do not hollow out the cats. Maybe the best reasons being that you will not gain power and will loose low speed torque and it will sound bad. BTW, this is NOT because the engine wants backpressure. It is because you create a low speed plenum in the exhaust that actually reduces flow and hence the loss.
Old 03-17-04, 05:51 AM
SupraBlur
SupraBlur's Avatar
It will also SMELL bad. A good alternative is to use a high flow cat that matches the diameter of whatever high performance cat-back you decided to go with if any. Random Technology is a very reputable brand in this department.
-Ray
Old 10-18-04, 07:57 PM
Gixer 1000
Gixer 1000's Avatar
hate to bring up an old thread, but im using 2 bosch universal o2 sensors in my xerd header.(93 sc300) the sensor after the cat is a 4 wire where as the first 2 on the stock manifold are 1 wire. my exhaust guy installed a third universal to replace my 4 wire (he didnt know it was 4, not 1)
so its not installed and no check engine lights have come on yet, but does anyone think the uni. sensor will work in place of the 4 wire, or should i just leave it out ?
no cats btw,just xerd to resinator to duel magnaflow 14829
sounds EXACTLY like this clip on intellexual.net
http://www.intellexual.net/movies/SC300-Magnaflow.mp3
im gonna post up lots pf pics in 1 big thread soon.
TIA
Mr.Gs_GTE
SC- 1st Gen (1992-2000)
02-07-16 07:38 PM
brad11140
04-24-14 09:19 AM
cheez
05-25-10 08:24 AM
turbodremz
02-04-10 10:23 PM
96RedLexSC
12-08-06 07:50 PM
Quick Reply: O2 Simulator
