Bundle of most thread links covering 92-94 SC300 5-speed & old R154 short shifters
I noticed there wasn't a main thread to collect all of this as the info has been scattered around in many threads over the years. Primarily these links cover the vintage C's short shifter for 91-93 Toyota Soarer 1JZ R154 vehicles and the 92-94 USDM SC300 original W58 5-speeds which use the exact same shifter setup and placement in the transmission tunnel. Also the SupraSport V2 and V3 short shifters which are improved copies of the old C's design. I've commented in a few of these over the years but this should be very comprehensive for anyone in need of specifications and compatibility with these designs. In addition, links and info for other short shifter designs for the early R154's and early SC300 W58's should be added.
https://www.clublexus.com/forums/sc-...r-on-r154.html
https://www.clublexus.com/forums/per...hifters-3.html
https://www.clublexus.com/forums/per...hifters-2.html
https://www.clublexus.com/forums/sc-...t-shifter.html
https://www.clublexus.com/forums/per...shifter-2.html
https://www.clublexus.com/forums/sc-...shifter-2.html
https://www.clublexus.com/forums/per...t-shifter.html
https://www.clublexus.com/forums/per...tension-2.html
https://www.clublexus.com/forums/sc-...acement-2.html
