Any Shortcuts to Changing Front Turn Signal Bulb?
Hi,
My front left turn signal started winking fast, and sure enough, it is the driver side turn signal bulb. I have the car on some drive up ramps , and I have removed the front air dam cover, as well as the left side cover, except inside the wheel well. Will I need to remove the front left wheel, also?
Any suggestions would be appreciated.
It's tough getting in there, you mentioned the driver side, try removing the battery and see if you can gain any access from the hood. If not then you will have to remove the wheel well cover, but not all of it, just the bolts on the fender. Removing the wheel will make it easier but you should be able to if you turn the wheel to the right giving you more access. You'll need a long extension as well to remove the two bolts behind the headlight, it's a real tight spot especially with the washer fluid right next to it.
Got it replaced. Removed the battery tiedowns and slid battery over for access. I didn't have an Amber bulb, so I finally found it
I didn't have to remove the wheel or any covers
