Vibration sound from rear end
I have a slight vibration coming from the rear end. I have just replaced all my tires. I only notice the vibration sound at speeds of 70-90, it seems to not exist below 70. Does anyone have an idea what may be causing the sound
Speed sensitive vibration is almost always a tire issue. If it started after new tires installed, start with that. When the tire shop removes the rear wheels, look for excessive amounts of wheel weights. Most tires should balance out with only a couple of oz.s on it. Could be a bad tire, and they put it on the rear to cover it up, and hope it would be ok, or you wouldn't notice. I worked in car/pickup tire shops and a semi truck shop for 20 years. I dealt with this every day. Other possibilities could be bent rim, warped brake rotors or a bad 1/2 shaft (if all wheel drive). Good luck!
Phase
03-10-17 10:11 PM
