Where to get MKIV Supra front clip these days
Originally posted by SinisterSC
If you're gettin a 2JZ-GTE from japan, it may be tempting to get a newer motor. but do not get a VVTi motor. They are garbaage when turbo'd. They don't hold as much as the no variable motors and are harder to tune
well VVTi is never been hard to tune or anything.. only problem was on vvit was that there was no cams available for those vvit.. however, the HKS released the cams timming controller, which can control the cams timming, also they have a cams comming up soon...
vvit can make as much power as non vvti, plus if you going to keep it as just a BPU, then vvti is alot faster than non vvit.... it has been proofed on option magazine at japan....
Good engine
Good engine
The cam's are basically identical. People put different cams in either OBD1 or OBD2(VVTi) engines with no problem. Its not like 97-98 Supras are unable to use upgraded cams.
Good engine
Good engine
Chicago Lexus Club Moderator
Originally posted by Supratt85
Theres a guy out here in Chicago who just crashed his 6 Speed MKIV, it has damage but i think you could easily part out everything out of there, if you want i can get you his info, or you can go onto Supraforums.com and look it up under the for sale section
Chris
Originally posted by 5speed300
Maybe I am wrong but I didnt think that any US spec 2JZ-GTEs came with VVTI. Even if they were OBDII
Originally posted by AzLex
You are correct the only vvti supras were 98 non turbos.
I belive there were not VVTI Supras in US (both turbo and n/a). I do belive cars such as the SC300 in mind 97 started coming with VVTI and 5 speed automatic tranny. I also belive there were both turbo and non-turbo supras in Japan with VVTI starting 98. I may have the years wrong but I do belive there were no VVTI Supras in US.
Chris
Theres a guy on supraforums who has I think a 98 VVTI NA supra.
I'm buying a JDM Supra front clip with 6 speed transmission this month. Total price wil be 4500 bucks. I specifically avoid VVTi engines simply because I don't want something that too much different from US spec.
Chris
Originally posted by DIrEctQL
... it's posible he swapped it in ... or perhaps he really did get one like that. One thing is for sure VVTi SC300 is slower, perhaps same applys to Supra.
Chris
Chris
whats the point of keeping it a secret. we come on here to swap info to help each other out yet you can't tell us where you bought your motor from? im not trying to flame you or anything but i just think its childish..."imma keep it a secret" . if everyone kept everyhting a secret than the board or any other board wouldn't even exist. anyways diffrence between the usdm and jdm motors are the turbos, cams, injectors, and map sensor instead of maf (us).
Chris
Chris
