94 SC300 Denso Fuel pump died less than 15k mi.
Old 10-15-18, 02:11 PM
Modenaro
Modenaro's Avatar
Default 94 SC300 Denso Fuel pump died less than 15k mi.
I replaced my fuel pump 1.5 yrs / 15k miles ago with a new Denso $150.00 fuel pump.
Now the fuel pump is bad again? Engine starts when I spray in the intake.
So, is the Lexus pump from the dealership the way to go?
Anyone else run into this?
Thanks
Old 10-16-18, 01:06 AM
KahnBB6
KahnBB6's Avatar
Received 1,250 Likes on 870 Posts
If you used the Denso #950-0109 fuel pump kit then that will be exactly the same thing the dealership will sell you... just at a significantly higher price.
I doubt it is your fuel pump after only 15k miles of use. The Denso OEM pumps last an extremely long time.
When you spray the intake I am assuming that the engine only runs for a brief time before dying again?
Have you run the fuel pump bypass to make sure your fuel ECU isn't the issue?
To do this, open the underhood diagnostic port and jumper or use a thick paper clip between pins FN and +B and then start the car. If there is no change then your fuel ECU is not the issue. If the car starts right up then it probably is.
Old 10-16-18, 03:48 AM
Modenaro
Modenaro's Avatar
Jumper worked. fuel ECU problem.
Will pick one up off ebay.............
Old 10-16-18, 09:15 PM
zazzn
zazzn's Avatar
Probably the capacitors on the ECU are bad, just open and look if any are bludged and replace them.
Old 10-16-18, 09:27 PM
RXRodger
RXRodger's Avatar
He meant fuel pump ecu, not the main ecu.
Old 10-17-18, 11:25 AM
jdmek998
jdmek998's Avatar
Just bypass the Fuel ECU for no further issues. I bypassed about a year ago with no thus far.
Old 10-18-18, 11:23 PM
KahnBB6
KahnBB6's Avatar
Installing a new or known good Fuel ECU will cure the issue. If you can locate a good one then that will be the easiest fix. If you do happen to choose the alternative Fuel ECU bypass (the "+12V Mod") it's best to do so with a relay for safety so that the pump shuts off whenever the factory EFI Main circuit is off.
Old 10-22-18, 11:49 AM
Modenaro
Modenaro's Avatar
Is there a way to test the "Fuel Pump Control Module Relay" ??????
I purchased a used one from a dealer that said its been tested
and in good working order. The seller sells lots of these, and has others just like it for sale.
Installed new part, ran for 5 seconds then quit.
Still starts and runs fine when I jumper +b & fp. Could it be anything else other than the fuel pump module?
Thanks!
Old 10-22-18, 01:31 PM
Modenaro
Modenaro's Avatar
Screw it. Bought a new one from discount parts monster... $372.00 shipped............
Old 10-22-18, 06:17 PM
KahnBB6
KahnBB6's Avatar
^^ That's about right for what a new one costs.
FYI it is helps in the future, the Fuel ECU test procedure from the SC300/400 TSRM:
Old 10-22-18, 08:14 PM
Modenaro
Modenaro's Avatar
My local dealer wanted $590.00
I really hope thats the problem..............Ha!
Old 10-23-18, 10:04 PM
KahnBB6
KahnBB6's Avatar
Yikes! Next time try Lexus of Pembroke Pines Trademotion or Amayama.
Old 10-24-18, 07:37 AM
Modenaro
Modenaro's Avatar
Thanks for the links. Paid $354 / $372 shipped from discount parts monster. Just a little under Pembroke Pines Trademotion.
My dealer wanted $590. But I never buy anything there...........
Looks like Amayama is $212 / from Japan. Not sure its OEM though?
Part # 89570-24010
I didnt test mine, but from everything I have read, its the only thing it could be. Fingers crossed. LOL LOL
And thanks again KahnBB6 for all the help! Much appreciated!
Old 10-31-18, 12:04 PM
Modenaro
Modenaro's Avatar
Now I am a bit sick to my stomach. Plugged the new one in from Lexus and it just turns over. Does not start........
Old 10-31-18, 12:45 PM
KahnBB6
KahnBB6's Avatar
Do you mean you plugged in a new pump or that you plugged in a new (or used) Fuel ECU?
Sorry, mentally catching up. It was a replacement Fuel ECU that you bought.
I would do the fuel ecu bypass test and see what that does with your new ecu. Then I would remove it and test the pins with a multimeter as laid out in the TSRM pages above.
If plugging this one in results in still no solving of the issue.... or different symptoms altogether... then you’ve got to test it and confirm whether it’s doing what it should or not.
It is not a complicated electrical circuit or computer but if it’s a reconditioned unit the company that did that reconditioning needed to make sure it checks out electrically.
If it doesn’t I would return it for another one :/
Quick Reply: 94 SC300 Denso Fuel pump died less than 15k mi.
