EGR Block-Off Plate Kit
Hey folks, anyone tried this on the SC300? I wonder if the Supra Turbo one will fit on our engine.
Notes:
The factory EGR system was designed to assist in emissions reduction by allowing hot exhaust gases to be recirculated into the cool incoming air within the intake manifold. While this was a great idea from an emissions standpoint, it has horrible effects on a turbocharged vehicle that relies on cool charge air temperatures to make horsepower. Even removing the vacuum hose from the EGR valve does not stop this process, as exhaust backpressure still manages to open the valve under boost. Stop these hot gasses from ruining your cool air the right way, by installing a pair of PHR EGR block-off plates! Machined from 1/8" 6061 Aluminum and hand-polished for a show-quality appearance. Accept no cheap imitations cut from thin material that warps and leaks, go with the best! Price: $90.00
Notes:
I use the egr block-off plates for the supra. I had to open-up one of the holes in the plate for the TB for it to fit. Had no other problems. I have a 92 that did'nt have the egr temp sensor, so I did'nt have to use the resistor to fool the sensor. Goto horsepowerfreaks.com and select MK3 Supra as your vehicle. They have been running a sale on them for months. $45.00. They look like the same ones I paid 90 for. Hope this helps.
gadgetSC-t
gadgetSC-t
this is where i got mine
http://www.mohdparts.com/egr_mods/2/
they worked fine on my 93 sc300
i wouldnt pay double the price. and be shure to check this out when doing this mod
http://www.mohdparts.com/egr_mods/defeat/index.html
Throttle body mod is next for me.
I passed emmissions with the EGR block off. My readings were not near the limit. In Ohio, they do an idle test and a 30mph rolling dyno test. The most important factor for me was to put on a new and working catalytic converter. Its a pretty stringent test, but I don't know how it compares to other states.
Originally posted by aliga
Take the gasket, trace it on a piece of steel, and make the plates yourself.
Originally posted by Hermosa
Hey Keith,
This is off topic but I noticed the 13B in your name and was wondering if you would ever try putting in a 13B into an SC300.
- Mike
Hey Keith,
- Mike
I've lived and breathed rotarys all my life, and my Lex is my first piston engin car I've ever owned. If I were to put a rotary on the SC, It would be a 3-rotor for sure with twin non sequential turbos. The 13b would just be way too small, and would throw off the weight balance of the SC. Plus, the added Hp for the heavier car would be better too. I might try to do it if I had a doner SC 300- I have several spare engines and tranny's sitting around....hmmmmmmm. Now you got me thinking.
It was sweet, I used 2- 13b's on a solid wing stunt ultralight in a push configuration. Street ported with a 7 psi supercharger on each. It wasn't cheap, but each engine put out over 315 hp at the fly. Everything was mild on the motor for reliability issues. The thing screamed- I got to go on a ride with it.......now I'm a pilot and all, but I like to stick to planes with a floor in them! That lawnmower with wings was about twice as fast as a 172, and the friggin wings would bow under hig g's. Needless to say I enjoyed the ride but was glad to be on the ground.
