1998 sc 300 knock sensors
![](https://cimg3.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1500/knock_sensor_81d583cd1a04753a38a30441c63711e8fa51ded7.jpg)
ok , I got them, last questions, where is the best place to purchase these and how long should this job take for a good tech! thanks for all your help
I believe those are your front and rear knock sensors and you can buy those from Toyota for a ( n/a Supra) (recomend toyota) from year to year the sensor connectors are different.
Your other option is to source another sc in the junk yard and pull it off, they’re usually a couple of dollars.
Depending what mechanic works on it, it can take a couple of hours at max, working from the bottom is a little easier I think!
^^ This!
Also, OP, just fyi the new Toyota early replacement knock sensors are P/N 89615-22030. 1998-00 should be 89615-12090. Highly recommend only the Toyota sensors be they new or used. About $160-180 MSRP each but you can get them much cheaper from Amayama.
