where to find a built auto tranny for sc300
Old 08-02-03, 11:44 AM
soarer NAT
soarer NAT's Avatar
Default where to find a built auto tranny for sc300
i have a turbo sc300 auto, and in about a month im going to have around 450-500hp on the car, and im pretty sure the stock tranny wouldnt be able to handle that, so i was wondering does anyone know a place that can built my tranny. i also could make my car a 5sp, but i dont know if i should or not. because i dont want it to give me problems later on.
so if you guys know a place that can built auto trannys let me know. ( if you know their # or website post it)
Old 08-02-03, 11:47 AM
GRIFFEN
GRIFFEN's Avatar
try level 10
level ten
Old 08-02-03, 11:51 AM
soarer NAT
soarer NAT's Avatar
thanx, but do you know any place in southern cali
Old 08-02-03, 01:09 PM
Ebanks
Ebanks's Avatar
If Level Tens reputation is accurate I would stay about as far away from them as possible.
How much money are you wanting to spend?
-Ethan
Old 08-02-03, 05:52 PM
BlueC
BlueC's Avatar
dont you basically need a valve body recailibration and a higher stall torque converter to help handle the extra power? I was thinking you'd really only need an ENTIRE new transmission if you were going for like 600+hp
Old 08-02-03, 10:21 PM
GRIFFEN
GRIFFEN's Avatar
whats wrong w/ level 10
Old 08-02-03, 10:23 PM
soarer NAT
soarer NAT's Avatar
there is notin wrong with level 10, i just wanted a place closer to me.
Old 08-03-03, 11:48 AM
GRIFFEN
GRIFFEN's Avatar
whats so bad w/ level 10 its good for me cause their right in jersey
Old 08-03-03, 01:49 PM
legendary
legendary's Avatar
Level 10 has mixed reviews.
Look them up on Google or Yahoo
Old 08-03-03, 05:56 PM
bambooluv
bambooluv's Avatar
www.boostlogic.com
Old 08-03-03, 07:06 PM
AzLex
AzLex's Avatar
There trannys break even faster then the gen1 SP trannys.
Old 08-06-03, 10:08 AM
Marlow
Marlow's Avatar
I'll second the boostlogic vote. Kean is working on a tranny for the SC's and a new NA-T turbo kit as well.
Old 08-07-03, 08:34 PM
racing fan
racing fan's Avatar
We just started tearing into a n/a tranny for R&d on it. Soon we will be able to provide a good affordable tranny upgrade for teh 2jzge. The turbo kit is almost done being fabbed.. FMIC is much bigger than standard spearco stuff on other kits.... I don't get to check these forums much so email zohair@boostlogic for more info
Old 08-08-03, 07:11 AM
Onelove
Onelove's Avatar
2 Places, if your on the west coast then check out http://www.phoenixhardparts.com
Sound Performace does good work (gen 2).
You could always do the Turbo 400 conversion, not sure if your looking to go that route.
And stay as far away as possible from Level 10.
Old 08-08-03, 10:43 AM
DaveH
DaveH's Avatar
Also, if you choose to use a AEM ECU, then you can use the TT auto tranny. Just a couple of extra wires to run.
BTW, I have had spectacular luck with my SP 1st gen trans. 3 years now and over a half dozen 10 sec passes at the strip. Still works like when new.
Quick Reply: where to find a built auto tranny for sc300
