Dang dang added atf to a once perfect transmission.
10th Gear
![](https://cimg2.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1124/155379252892942449410_8841be6a325284cc56fbf978865afdd818eadd30.jpg)
I wanted to be safe , figured how could it hurt...it was a tiny bit low . So I added a quart.
Driving it on 410 and I smelled oil....looked in my rear view. Huge cloud of smoke by me. Not sure what I had done so I immediately pulled over. Call the wrecker had it flat bed to my house. Then I remembered yesterday I added a quart of ATF. The fluid continue to flow after I turned off the car I thought it would have been empty but it wasn't.
But it was low so I went to add some and it started coming out of the hole that you can see the flywheel ......man I'm so sad and it's my ride to everything.
224 410 9664
If you know what I broke lmk.
10th Gear
