where are the Transmission hoses to radiator for cooling it?
where are the Transmission hoses to radiator for cooling it? where to they hook up to the radiator, i thought ive found them before but today when i went to look again to do a trany flush i couldnt find them
if you are automatic you have a tranny cooler, if you are 5spd I believe you don`t. anyways on the automatic the send and return lines are right next to eachother on the passanger side of the engine. Look in this pic at the two lines toward the bottom (they go under the motor mount) that is them.
