Car wont start
Crank but won't turn over is a contradiction, do you have
Crank, no start (engine rotates but doesn't start and run)
No crank, no start (nothing happens, no starter movement)
Looks like a no crank/no start going by your 10 second video.
you probably have a battery, power, or wiring problem , possibly crank position sensor open? Dead battery? or just a bad starter. You can manually make the starter work two ways to eliminate or prove where the fault is.
You can jump the starter relay or jump power to the correct terminal on the starter itself not sure if urs is 1 wire or two on the connector you plug into the starter (watch youtube videos if you dont know what im talking about) =)
