Engine Mounts
Old 08-20-03, 04:08 PM
SC3005SP
SC3005SP's Avatar
Default Engine Mounts
Hello,
I Have an SC300 1992. I was wondering if any one can reccomend/ tell me where to find a good set of aftermarket engine mounts. Like Hasport for Hondas. Any help would be greatly appreciated.
-Thank You,
-Brian
Old 08-20-03, 09:49 PM
bmsport
bmsport's Avatar
As far as aftermarket goes all i know about is PHR..
http://www.powerhouseracing.com/supratt_othereng.shtml
But for OEM mounts, you can get them cheap here..
http://www.parts.com/index.cfm?actio...&target=window
Old 08-21-03, 12:30 PM
bmsport
bmsport's Avatar
I just ordered the PHR today, since the trd are on backorder for 4 weeks!
Old 08-21-03, 01:02 PM
boredguy77
boredguy77's Avatar
I know I should know this, but I don`t ...so can someone explain what the reasoning is behind aftermarket motor mounts?
Old 08-21-03, 01:21 PM
quikturbo
quikturbo's Avatar
Aftermarke engine/motor mounts, like the TRD and PHR ones are made to be a bit stiffer. They keep the motor from twisting in the engine bay. Usually stock rubber mounts have a good amount of give, to eliminate road noise and vibration. However, with lots of HP, a hard launch can really twist (brings me back to my mustang days, and using a chain to secure the motor in one place in the engine bay )
I've got a set of TRD mounts in mine and don't really notice much difference compared to stock.
Chris
SC300TT
Old 08-22-03, 09:33 AM
boredguy77
boredguy77's Avatar
ok, makes enough sense. Thanks for the quick lesson
Old 08-22-03, 09:38 PM
Lex Luthor
Lex Luthor's Avatar
Boy I remember that, did it on my F-bodies too, and used a tie-down ratcheting strap on the GN's, wouldn't mind a set of the TRD mounts.
apptec
06-22-18 09:43 PM
Gskis
GS - 1st Gen (1993-1997)
03-21-10 12:26 PM
CDY
12
03-30-08 09:42 PM
StockGS400
Performance
11-26-06 12:23 AM
VSsc400
SC- 1st Gen (1992-2000)
10-23-02 08:00 PM
Quick Reply: Engine Mounts
