Forced Air Tech seems to be ready
go to forced air tech website. their 1UZ-FE supercharger is ready to ship.
but no details.....
already emailed them for info....
link for the lazy
http://www.forcedairtech.com.au/
but no details.....
link for the lazy
That S/C looks awesome. I'm still wondering if it will work with the US model and what other types of mods need to be done in order to do it properly(injectors, fuel pump, ECU?). This makes the 2nd kit I know of to be available. About time we got some real power.
ive been talkin to him for a while about this. he can send u an email with an attachment that will go into more detail on what you need and how much estimated HP and all that. get him to send u that attachment and it will answer many of your questions. it also comes with a list of things that you can order from them to make your supercharger efficient as possible. seems like a great guy. if anyone gets a S/C kit from him please tell me how it works out.
better yet... can you post all the details he sent you?
thanks
can you send me the info that he sent you? I have cash ready on hand to buy right now. but I need to know all the details.....
Seriously, forward that info along to me as well. I'm not ready to buy yet but I will be in Feb. Gotta wait till the money starts flowing again.
ok. well instead of forwarding this info to everyone. ill just post it up..heres the first part. i have to search and find out where the other infor is. i cant find it. when i do ill post that up as well. heres a parts list with stuff u may want and cost. all these costs are in aussie dollars as well.
1uz-fe Toyota/Lexus Supercharger Packages
As vehicles are different from model to model and country to country, and the availability and the preference of many fuel and engine control systems, Forced Air only focus on supplying fabricated components leaving the balance of fitting and kit to the installer.
Forced Air Tech can help if required in choosing or even supplying other required components.
What Is Supplied In The Base YT 1500 5, 7 & 12psi Kit.
- Supercharger Manifold AUS $2,000 + GST
- Supercharger Package
YT 1500
Top Plate
S/C intake AUS $3,475 + GST
- Accessories
Idle bi-pass
Thermal isolator
S/C pulley
S/C Belt AUS $745 + GST
What is NOT! Supplied (but on request can be supplied)
- Fuel Management
RRFR (5psi only) AUS $275 + GST
(Rising Rate Fuel Regulator)
- Fuel and Ignition Management
SMT 6 (7psi) AUS $550 + GST
Or
Wolf (7 & 12 psi) AUS $1,300 + GST
Or
PRS 8 (7 & 12 psi) AUS $1,300 + GST
- Supplementary Injectors x 2 (C/W Fittings)
7 & 12 psi AUS $350 + GST
- Fuel system upgrade
12 psi AUS $1050 + GST
- S/C Drive Upgrade
12 psi (HD Tensioner) AUS $350 + GST
- Water Injection system
5 & 7 psi AUS $350 + GST
7 & 12 psi AUS $950 + GST
- Fitting and tunning
Local On Quote Only
What Is Supplied With The Opcon 7, 12 & 15 psi Kit
Opcon MX420
Top Plate
S/C Intake AUS $4,150 - GST
- Accessories
Idle Bi-Pass
Thermal Isolator
S/C Pulley
What Is NOT! Supplied (but on request can be supplied)
- Fuel & Ignition control
SMT 6 (7 & 12 psi) AUS $550 + GST
or
Wolf (7, 12 & 15 psi) AUS $1,300 + GST
or
PRS 8 (7, 12 & 15 psi) AUS $1,300 + GST
7, 12 & 15 psi AUS $350 + GST
- High Flow Injectors x 8
12 & 15 psi AUS $760 + GST
- Fuel System Upgrade
12 & 15 psi AUS $950 + GST
- S/C Drive Upgrade
7 & 12 psi (HD Tensioner) AUS $350 + GST
or
15 psi (separate 8rib drive) AUS $950 + GST
- Water Injection System
7, 12 & 15 psi AUS $950 + GST
- Fitting & Tunning
Local On Quote Only
- Basic Engine Mods & Accessories (recommended minimum for 12 & 15 psi)
Decompression Plates AUS $ 350 + GST
HD Valve Springs AUS $ 450 + GST
Iridium Spark Plugs (colder) AUS $ 192 + GST
Extractors (custom) AUS $1,200 + GST
Hi-Flow Exhaust AUS $ 450 + GST
Optional Engine Mods
The most unique thing about forced induction is you can increase power on a standard engine without many modifications to the host engine.
But if you are going to go for hi-boost or searching for optimum performance, well-planned engine mods will improve the overall package.
Every supercharger will be rated by air flow and how much power it can potentially produce in an ideal installation, but when we start with a standard engine and raise its performance objectives by increasing the boost you need to match key engine and drive train components to suit.
While the modifications mentioned above are recommended for the 12-psi package and will work adequately to produce 420 HP the following modifications are required to lift the power expectations above that, boost alone will not do it.
Proposed Engine Mods and accessories to achieve 500hp and greater.
- Performance Camshafts (exchange)
420+hp AUS $ 850 + GST
550+hp AUS $2,250 + GST
- Throttle body & intake
85mm single throttle body AUS $ 650 + GST
- Flowed and ported heads
420+hp AUS $1,100 + GST
- Low comp pistons
9:1 TBA
8:1 TBA
- Adjustable Timing Gears (Exchange) TBA
- Transmission mods TBA
NOTE: 1hp = .75kw
YT 1500
Top Plate
- Accessories
Idle bi-pass
Thermal isolator
S/C pulley
- Fuel Management
Or
Or
- S/C Drive Upgrade
Local On Quote Only
Opcon MX420
Top Plate
- Accessories
Idle Bi-Pass
Thermal Isolator
S/C Pulley
or
or
- S/C Drive Upgrade
or
- Fitting & Tunning
Local On Quote Only
- Low comp pistons
9:1 TBA
8:1 TBA
NOTE: 1hp = .75kw
sounds to me as if, potential for a blown engine if left to the novice and or a big hole in your pocket book. I think any good engineering company of any product should have pre-configured packages that have been tested and proven with operating parameters so that you know what tha hell you're gettin' from the onset.
These other kits are DIY pieces from cars w/ different emissions, ecu, etc. and you have to tweak things yourself. Thats great if you have a speed shop to do all the work, but its a whole nother' ball game when everything is coming halfway around the world from a car that has a different computer and you have to piece it all together yourself.
So, as far as I'm concerened, there are no US designed S/C kits available at this time. There are S/C pieces that can be assembeled to work, but they haven't been tested on a US spec car. Nor are they being sold as a bolt on "kit".
Just my thoughts on the topic. So flame away, as I'm curious as to how others feel.
Keith, I am with you on this one. Might as well get a one-off if you are going to purchase the AUS kit and guesstimate what is needed. I anxiously await Ryan's kit. Hurry and get your credentials man. We need to talk
Gents:
SOON...VERY SOON... Final product issues are being tweaked. Website is in design stage, PRODUCTS (Plural) will be listed and explained, and just before release- CL approval will be applied and approved.
We've all waited this long, just a little while longer...
Altstadt
Altstadt
