2JZ-GTE short block and SC300 components?
Are the components mated to the SC300 pretty much the same as the Supra TT? (Upper pieces)
I ask because I am interested in a single Turbo upgrade, with SC300 parts (head, etc.), and a 2JZGTE short block. Basically removing the SC300 block and installing the 2JZGTE, with a Supra upgrade.
How much horsepower can the SC300 Auto and Manual transmissions withstand?
Well, from what it looks like the 2JZ-GTE BLOCK will bolt up to everything the GE has, so it looks like...
SC300 car $6500 (autotrader)
2JZGTE new short block $2200 (Toyota)
Turbo kit $5000 (Toyomoto)
Not too bad. For about $14K.
But it looks as if I'd be saving a lot of cash (and being as sucessful) with just an SC300, a Toyomoto kit, and a double head gasket. For about $11K.
I'd rather have a custom kit, but by the time I'd have everything together it'll be 2006.
Originally posted by motorheaddown
About headgaskets, I did take the time to measure the change in head clearance before and after installing the thicker hg. The stock clearance is about 0.056". After installing the hg (which was actually 2.7mm umcompressed), the final squish clearance is about 0.146". The resulting increase in clearance volume changed the compression ratio from 10:1 to 8.4:1. Perfect for a turbo-charged motor. Next time, however, I probably would just go with a TT hg especially in combination with meth injection. In fact, it should be possible to run stock compression at high boost with chilled intake air using Derek's injection system.
I have been preaching this for MONTHs and motorheaddown finally proved it ...he and I BOTH used a 2mm headgasket (2.7mm uncompressed, as he said) and I swore up and down it would put the compression close to 8.5:1 and no one believed me. I kept telling people that a 3mm and double stacking was overkill and would give you 8.0:1 or lower compression ... and because of what he proved from the 2mm headgasket, I am still sure I am right
... and I STILL have an HKS 1.6mm headgasket laying here, brand new, for sale STILL, which would be perfect for an NA-T project. I only didn't use it because I was in the bandwagon thinking I needed a 3.0mm headgasket, and when they sent me the wrong gasket for the SECOND time, I figured screw it, and I used the 2.0mm that they sent me incorrectly after incorrectly sending me the 1.6mm ... so I have been sitting on it since.
Yeah if anything i would swap out the GE head for a GTE head before i went out and spent $2k on a GTE shortblock. Plus than you can use the oem supra TT head gasket and get what is it 8.875:1 compression!?!. I went all through the choices before i just said screw it and dropped the full GTE in.
Angel - Lance Ho Lung calculates two TT head gaskets with GE pistons to come out to 8.5:1, Larry Prebis calculates it to come out to 8.6:1. There are other reasons for doing it too, went thru this same topic in the SP63 thread, different pistons, lack of oil squirters, etc.
bmsport - Many believe the GE head to outflow the GTE head, so that would be a waste, and you can use the TT head gasket on both motors, GE and GTE, without having to swap the head.
