1992 sc400 idle issue
1992 sc400 has intermediate idle drop that isnt constant and no power in gear
went through and put a screw driver on all the injectors, they all sound fine, all the cylinders seem to be functioning so not a coil, plug wire, plugs or distributor and or rotor, may be the tps, i already pulled and cleaned the iacv and egr, new fuel filter, new pump, 12v mod, switched relays with the dimmer and its still doing it, switched to a fresh fuel pump fuse, maf doesnt seem to be affecting anything, possibly antitheft ecu prob, ign switch
Wicked-SC
Performance & Maintenance
12
06-17-05 08:15 AM
