1994 sc400 system too lean
What’s up guys so I have a 94 sc400 with 192k miles. Runs perfect but the other day I got a check engine light and did a code scan for codes 22,25,31. The car tends to give a little jump when first pressing the throttle in drive probably due to bad map sensor. When I went to re check the codes all that’s coming up now is code 25. Any thoughts on testing or should I replace the ect and map first? Thanks
Code 25 is typically an O2 sensor malfunction, however, also check for vacuum leaks. Sometimes bad plugs/wires/distributors can give you a similar code, but I'd start with primary 02 sensors and go from there. Someone may chime in, but, do a few searches on this forum and that seems to be a common consensus.
Solved!!
Changed my upstream 02 sensors and light hasn’t came back on and it’s been a few days. So far so good. Does anybody suggest changing the other 2 soon to be preventative? 193k miles
If you changed both primary sensors and the codes went away, then you're fine. The rear O2s only tell the ECU the cats are working so they don't need to be replaced until they stop working altogether. That's rare on the OBD1 cars.
sc300jon
SC- 1st Gen (1992-2000)
10-15-01 11:44 AM
