New SC300..start issues, but!
Hello all. Just recently picked up a 92 SC300 for free. It won't start. But I did put in a new battery and all the electronics do work as well as windows, seats, and mirrors. When trying to start it does click but won't even turn over. I tried jumping the TE1 and E1, did not get the engine light to come on at all. Used the OBD hook up at the kick plate. But the engine and oil lights do stay on even after 2-3 minutes. The gas gauge doesn't register either (might be bad). But for free a little investment might be worth it. The next steps are the alternator, starter then fuel filter. Read somewhere else about using cleaner near the MAF sensor and not to do that. Also inspected the IMC on the driver fender and it looked pretty clean with no corrosion, Same thing with all the fuses in the engine bay.
Kira X,
Thanks for the reply. I'll give that a try and see where it leads. I need to drain the fuel tank and lines anyway. It has been sitting since 2017.
The following 2 users liked this post by gerrb:
japsc85 (09-07-20),
Nokton40mm (09-07-20)
Car is been sitting since 17 definitely a starter issue you could probably take the starter apart and clean the contacts and it probably be good moisture probably has gotten up in there and now the Brushes are not making good Contact
One click of the solenoid instead of mutliple rapid clicks does usually point to a starter problem but try this first, try and push the shift lever toward the dashboard, I had my car not start once and my mech told me to do that because sometimes theres play in the shift lever where the sensor telling the car its in park is not engaged so pushing it forward a bit(gently) could help. Also maybe try and start the car in neutral?
try jumping through the relay, rule out the relay, but odds are its the starter. My truck did some stuff like that, power would cut out and would comeback after a few seconds..... My car does something similar, but I have to pull the starter relay and jump it to make it work and it turn on. If that fails like the one in my truck its definitely the starter.
![Angry](https://www.clublexus.com/forums/images/icons/icon8.gif)
Update to 92 sc300. Replaced battery, starter, starter relay, and EFI/Main relay along with oil change. Still no crank just the click. No CEL. But I still have the oil and battery light along with the tail lights (I think) light stay on even when trying to turn it over. I do not hear the fuel pump at all. Becoming quite baffled. I traced the battery leads and they look to be in good condition and grounded for the negative side to the chassis. I did find that the diagnostic port in the engine bay is very corroded thou. Someone outside of here mentioned seeing if the ECU is getting power. Since I have lights and all the electronics work. I have ruled out the alternator. Any other suggestions anyone might know of?
Any chance it may be the neutral safety switch gone bad?? If its bad it may think that it is in gear instead of P or N?? Additionally have you tried jumping it with a paper clip?? Another thing to look at would be the crank position sensor? My truck would do the same, but triggered a crank position sensor, but it was the starter for me....
Should be able to use an adapter for obd1 with a obd2
When you first key the car up you should see a check engine light for a few seconds before it goes away. Otherwise u have ECU, Crankposition sensor issues.
The fuel pump should turn on when you key it up and you should be able to hear it. Google - 12 volt fuel pump mod sc300 - and youll find how to just give the fuel pump straight power bypassing the fuelpump ecu.
Could be a bad negative from your battery/ or positive to the starter is corroded.
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
Any chance it may be the neutral safety switch gone bad?? If its bad it may think that it is in gear instead of P or N?? Additionally, have you tried jumping it with a paper clip?? Another thing to look at would be the crank position sensor? My truck would do the same, but triggered a crank position sensor, but it was the starter for me....
