92 SC400 Starting Mystery
I'm going to try to be as detailed as possible here but to start I have a 92 lexus sc400 that will start no problem, excellent in fact but after driving it for even 20 mins it won't restart after sitting off for several mins until the next day. This has been a very stressful issue for me as I have already replaced several components which include: both ignition coils, the battery, the alternator, has new starter and works, spark plugs and wires, heater hoses, does have 12 volt fuel pump mod, replacement of the ECU as well from tanin electronix. Car has fuel pressure indicated from the dampener screw popped up. Fuel pump is operational. I do have a small coolant leak from a water inlet bypass hose underneath the idle control valve which might acoount for the slight burnt coolant smell. Also power steering fluid does leak onto the alternator which to me doesn't seem like the real culprit here but nonetheless a serious problem. As to what is causing this start, sit, then no restart problem I am at my wit's end. I need some help! Cam sensors? Crank sensors?
Trying to start it the second time it will crank really good but won't turn over. My assumption is I'm having a sparking issue but I'm not certain. I can do some testing to answer questions too from my limited tool set. I have a multimeter and a test light on hand. Any clues to what I should do? It's hard to know where to start! Should I induce the symptoms of the no restart? Need a video? I can show it operational and then not? Help!
Just had this same issue last night.... Thought I would be stranded at work, with a dead cell phone, lol... Only difference mine is stock.. would crank but wont turn over.. I cranked it over 4 times, before popping the hood removing the covers and pressing in all spark wires. 5th time was the charm, but required the 1970's touch where I had to pump the gas to keep it running, idled rough after 15 seconds and maintained a decent idle based on sound as the tack stopped functioning... Strong smell of fuel out of the exhaust, apparently I flooded the engine?? It stayed on and made a long trek home of about 30 minutes on highway, idles very smooth and shifted really smooth, which hasn't been the case in a while.. Prior to this it had stalled under load of about 40 mph before it just died, restarted with no issues.. Brought it back to work today and it has been functioning without issues so far...
Would it be some of this ash in the air?? My Celica (DD) had a similar issue this morning as well, has had a rough idle and really low idle in gear this past 2 weeks, My SC is the back up and weekend warrior....
I had somewhat similar issues on my first SC. It was mostly a long-crank issue after shut off, not quite a cooling off thing like described above. If I'm remembering right, it ended up being the return hose to the gas tank was pretty loose on the fitting, allowing pressure loss after shutting off.
Will try to chase these hoses down. Its done it twice so far in 2 days, and don't really want to end up stranded....
Aniyah87
Performance & Maintenance
07-16-18 01:59 PM
