FYI - AEM ECU Availability
Old 09-14-03, 01:14 PM
Dew23
Dew23's Avatar
Default AEM ecu
Good news for all sc300 people 92-97 Lexus SC300 & GS300!
P/N 30-1101 Shipping September 26th, 2003 straight from aem site enjoy.
Old 09-14-03, 07:15 PM
Angel
Angel's Avatar
Wow ... I wonder what the difference is ??
Old 09-14-03, 07:16 PM
Angel
Angel's Avatar
That is actually quite depressing .. it won't be original or different when every other SC300 is running one
Old 09-14-03, 09:45 PM
Shellhouse
Shellhouse's Avatar
My thoughts exactly.
Old 09-15-03, 05:06 PM
Hermosa
Hermosa's Avatar
Does AC work using the Supra one?
Old 09-15-03, 05:19 PM
0l33l
0l33l's Avatar
If you do a 2jz-gte swap, could you use the new one designed for the lexus to power the GTE?
Old 09-15-03, 05:30 PM
Angel
Angel's Avatar
Yes.
Old 09-15-03, 05:32 PM
Angel
Angel's Avatar
The only reason you would do this would be:
1) put the AEM on the stock GE motor until you do the swap (which is rather pointless)
Otherwise, I would just get the GTE version AEM.
Old 09-15-03, 05:41 PM
0l33l
0l33l's Avatar
Sweet!
Old 09-17-03, 12:00 AM
bambooluv
bambooluv's Avatar
If I was to turbo the Ge motor and also do a distributorless ignition setup. Would I run the sc300 or supra unit thanks-pdang
Old 09-18-03, 07:31 AM
CmputerWiz
CmputerWiz's Avatar
SC300 / NA Supra unit.
You only use the Supra TT unit if you're doing the GTE swap, or you want to rewire it for fun.
SR
Old 09-18-03, 12:24 PM
Shellhouse
Shellhouse's Avatar
SR
It's really not hard to wire the TT unit. If you're doing a serious turbo conversion, you'd want to install MAP and IAT sensors, anyway. Neither Angel, tkr*sc300, or myself have GTE motors or heads..
Old 09-18-03, 01:59 PM
Lex Luthor
Lex Luthor's Avatar
Dew, have you been able to confirm if this unit will control VVT-i?
Old 09-18-03, 02:19 PM
Dew23
Dew23's Avatar
Lex i forgot i will do that right now for you.
Old 09-18-03, 02:29 PM
Lex Luthor
Lex Luthor's Avatar
Thx brother, i'm hoping the plugs @ the ECU are the same as well, if so and I could use the '97-down unit I would strongly consider going AEM instead of Autronic.
Quick Reply: FYI - AEM ECU Availability
