Fuel pump relay
Car starts and runs with 12 volt+ and ground applied to a spliced pump connection ,nothing else is wired to pump .car has issue with relays etc whatever ,This car has to run now there will be other days to track all this down. I need help with what I need to do to wire it easily to a 12 v source either the battery or some place easy to find how many amp relay etc if i have to use a toggle switch to cut on and off then thats ok but was hoping it be put somewhere where it would on and off with key
SpaceWizza
03-01-21 02:20 AM
MIGS
SC- 1st Gen (1992-2000)
12-18-10 07:07 PM
