Cheap turbo kit for SC300???
I was browsing supraforums and came across this site. www.nonturbo.com
They are selling a turbo kit for the nonturbo Supra. I was curious if anyone here knew what modifications would be needed to be done to get a turbo kit to fit onto our SC300's? Here is an excerpt from the site:
NonTurbo is now offering a turbo kit for customers who are wanting to choose the turbo route. This kit is half the price of the infamous turbonetics/f-max kit and is capable of double the performance.Automatics should expect around 300-320rwhp 7psi on stock compression! The 5 speeds will expect around 320-340rwhp 7psi on stock compression. If you add a headgasket to lower compression with 20psi expect 450rwhp! If you just want to add some horsepower to your n/a this is the perfect kit. If you want to build a 600hp monster this is the perfect kit for you also.
This is what you will receive with this kit.
T04E Compressor on turbo with GN Turbine Side with .63 ar.,
38mm Tial wastegate vented to the atmosphere,
Wastegate dumppipe,
3" downpipe,
Cast-Steel manifold
**The automatics will receive a TE44 turbo and 5spd PT52** This is not mandatory, it's just recommended if you are running the stock auto transmission.
**Available for 93-96 and 97-98 please specify when purchasing**
Expect around 6-8 weeks for delivery.
$2,000.00
Wastegate dumppipe,
3" downpipe,
Cast-Steel manifold
$2,000.00
not as much you think ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
he also said $2k is the filler price, when the website is fully running it will be less than that...
all you need other than this kit is fuel control, injectors, fuel pump, and FMIC (or an IC of some kind)
i would suggest: VPC/AFC, 550 injectors, walbro, and a FMIC
you'll still come out under $4k for this kit and have the fuel/turbo to make 500rwhp with a headgasket swap or who knows without the hg swap
there are still other misc things like the exhaust, clutch, boost gauge, etc... but thats the real expensive stuff
Former Sponsor
My costs in piecing together a kit:
vpc chip 72
fjo 666.61
dave h (525 injectors, pt51 turbo, dp, tial wg) 2025
vpc 450
walbro 99
smic 140
bov 183.99
ic piping ?
afc 221.5
ebc 430
oil lines 200
vpc harness 50
vpc mount 25
egr blockoff 53
silicon couplers 60
drill bit 21
tap 15
fipg 10
spark plugs 35
permatex 10
drill rental 32
brakes ?
tranny cooler 60
gcc 102.5
bov flange 62
casper sim 60
muffler 230
5313.6
vpc chip 72
fjo 666.61
vpc 450
walbro 99
smic 140
bov 183.99
ic piping ?
afc 221.5
ebc 430
oil lines 200
vpc harness 50
vpc mount 25
egr blockoff 53
silicon couplers 60
drill bit 21
tap 15
fipg 10
spark plugs 35
permatex 10
drill rental 32
brakes ?
tranny cooler 60
gcc 102.5
bov flange 62
casper sim 60
muffler 230
5313.6
Chicago Lexus Club Moderator
Originally posted by boredguy77
I would go with the e-manage instead, the vpc/afc combo gives you no control of timing. I don`t think you will get 320 rwhp at 7psi on a stock motor. I am at 6 psi, and it is fast but doesnt feel like 300 rwhp. Bean and I are both running this manifold, and I think we are both sufficiently satisfied. Dave is a great guy.
I will be getting E-manage with supprt tool and injector harness tomorow; however, I will be installing it on 2JZ-GTE.
VPC is set to 680 cc injectors and costs about 600 bucks! E-manage with injector harness (you can set your injectors) will run you below 400 bucks and can control ignition and much more than VPC/FC can.
Chris
vpc chip 72
fjo 666.61
dave h 2025
vpc 450
walbro 99
smic 140
bov 183.99
ic piping ?
afc 221.5
ebc 430
oil lines 200
vpc harness 50
vpc mount 25
egr blockoff 53
silicon couplers 60
drill bit 21
tap 15
fipg 10
spark plugs 35
permatex 10
drill rental 32
brakes ?
tranny cooler 60
gcc 102.5
bov flange 62
casper sim 60
muffler 230
5313.6
vpc chip 72
fjo 666.61
dave h 2025
vpc 450
walbro 99
smic 140
bov 183.99
ic piping ?
afc 221.5
ebc 430
oil lines 200
vpc harness 50
vpc mount 25
egr blockoff 53
silicon couplers 60
drill bit 21
tap 15
fipg 10
spark plugs 35
permatex 10
drill rental 32
brakes ?
tranny cooler 60
gcc 102.5
bov flange 62
casper sim 60
muffler 230
5313.6
I have been running it for about a month with all harnesses installed.
Chris
DaveH
