MK3 supra clutch in SC300 5 speed
Old 10-08-03, 01:20 AM
Tommyd1919
Tommyd1919's Avatar
Default MK3 supra clutch in SC300 5 speed
Won't a MK3 clutch and Pressure plate work in a SC300 5 speed? The reason I ask is I have one (Dual Friction ClutchMaster) and my car needs a clutch. I was thinking that I heard that. Let me now Thanks Tommy D
Old 10-14-03, 09:15 AM
kaotiq
kaotiq's Avatar
I dont think that will fit my friend. The MK3, use the 7M motor.... those clutch kits off the 7m will fit the 1JZGTE motor but not the SC300 2JZGE.
If you need a clutch, i have a brand new still in the box and original wrap ACT street clutch kit with new bearings, complete kit for $300. I dont need it anymore since im going 1JZ.
Old 10-18-03, 08:59 AM
suprang
suprang's Avatar
All w58 clutches are the same, so you have to get one off an NA
Old 10-18-03, 09:01 AM
suprang
suprang's Avatar
forgot to add turbo models use r154 tranny, those clutches are not interchangeable with your tranny. All this assumign the sc300 has a w58, which it should cuz the NA mkivs do to, so i dont see why it wouldnt.
If you are serious about big poewr, i would upgrade to a r154 with 1jz bellhousing, it will work great and can support gobs more power than a w58 can. Should drop right in too. that is unless you can afford the 6sp v160...
SC_SHAWTY
05-13-11 09:08 AM
sayayin
SC- 1st Gen (1992-2000)
04-08-11 05:46 PM
Blk97SC300
SC400 / 300 Classifieds
07-31-08 12:42 AM
sc1jzgte
06-01-08 09:27 AM
blaznsc4
02-07-06 03:00 AM
Quick Reply: MK3 supra clutch in SC300 5 speed
