2JZGE Boost questions...
Old 10-11-03, 09:43 AM
GSXtreme
GSXtreme's Avatar
Default 2JZGE Boost questions...
Im about to purchase an SC300 A/T or M/T undecided... Im definatly gonna put boost on it but something seems to puzzle me. I used to have a internaly-stock-motor Eclipse with a 60-1 Turbo with all the supporting mods to handle it, and didnt have to worry about anything when running 19-22psi on pump gas, 22+psi on racegas. But it seems like the 2JZGE-T people only run 10-15psi....even with a thick headgasket? Now to me that seems like Honda pressure but Im still new to the 2JZ motor.......Now my question is will the stock NA motor handle it if I bolt on say, a T61 Turbo, thick headgasket, and about 20psi on pump gas..? What are the limits to the stock bottom end motor??? In the 4G63 Eclipse world thats no problem. I guess I like to build a car to its limits..Plus I thought these Turbo Supra guys run like 25psi no problem all day long. Arent the bottom ends in both motors the same(other than oil squirters)? I havent came across a 2JZGE-T motor running anymore then 15psi...So if you are somoene out there running more than 15psi...please post on here...I interested to read about your setup
Old 10-11-03, 10:10 AM
Gixer 1000
Gixer 1000's Avatar
search ... its all here
2jz-ge = n/a
2jz-gte = twin turbo
this is a great start ...
http://www.intellexual.net/faq.html
http://www.turboforum.net/lexus/
http://www.datapathusa.com/sc300.html
Old 10-11-03, 11:26 AM
motorheaddown
motorheaddown's Avatar
Stock ge internals on race gas and spray: https://www.clublexus.com/forums/sho...threadid=97797 Is that stout enough?
You might run high teens on pump without knock on a well tuned ge motor, but I wouldn't do it without an AEM. The internal/external logging allows you to monitor knock that most if not all piggy-back units won't do.
-scott
Old 10-11-03, 11:36 AM
GSXtreme
GSXtreme's Avatar
Oh ok cool...it look like you CAN run decent on the stock bottom end motor. Thats what I needed to know. Who makes a decent thick head gasket for these motors??? Im lookin for something that will bring it down to about 8.5:1 compression.
Another thing is I havent really found a thread that talks about using a Supra automatic trans in a SC300, since the stock SC300 auto is inadequate for decent power. What are your thoughts on this?
Old 10-11-03, 12:24 PM
Dew23
Dew23's Avatar
The tt tranny is good to about 550 or so rwh with out mods per what the big single supra say.
Old 10-11-03, 10:26 PM
mrshabo
mrshabo's Avatar
gsx it's the tranny.. it can't support that much hp... well at least not for long.
Old 10-12-03, 01:02 AM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Old 10-12-03, 06:08 AM
marlew
marlew's Avatar
GSXTREME;
Hi mate I am new to this forum and I own a twin turbo soarer(from Australia)
I have had problems with my auto after pushing so much power through it .you will have to convert the kilowatts back to horse power (sorry mate)
the A340 auto trans is only good for 220 rwkw.(in standard form)
Above that I found out that it wants to fry the friction plates in the box .
A shift kit has fixed that problem and now is able to hang on to 260 rwkw
The next mod to be done to be able to get 320rwkw is a high stall converter and extra friction plates to be fitted to the box.
My car right now is putting out 246rwkw out of a 1jz with some big turbos (twin GT28 Garretts)
So with a few mods to the tranny it can handle a fair amount of power
Cheers
Lew
Old 10-13-03, 09:01 AM
GSXtreme
GSXtreme's Avatar
Hey guy, thanks for all your input. The auto tranny is all I was worried about with big HP numbers. But recenty I have just found a 1992 SC300 5spd pretty cheap. Now my next question is, should I prepare myself to do a 6spd swap to get the top gear highway speed I want??? Im gonna wanna run down my other buddies with Supras that can already run 165+mph. Will the stock SC300 5spd run up that high???
Should I maybe just get the Supra rear-end??? Whats the best way to get the top speed Im lookin for?
Thanks
Old 10-13-03, 09:24 AM
DIrEctQL
Chicago Lexus Club Moderator
DIrEctQL's Avatar
Thanks
The limit of 5 speed transmission is somewhere in the neighboorhood of 159 mph.
Chris
Old 10-13-03, 10:12 AM
RSTSpeed
RSTSpeed's Avatar
Stock SC3 tops out at 143mph (according to intelexual.net), but not sure if that's b/c of hp and torque, trans, or ???. Just my .02
Old 10-13-03, 10:48 AM
GSXtreme
GSXtreme's Avatar
OK so Im gonna guess about 150-160mph based on your opinions...Now do you guys know if its possible to just swap for a Supra rear-end?? I belive the Supra rear-ends have a lower gear ratio than the SC300s?
Old 10-13-03, 11:00 AM
RSTSpeed
RSTSpeed's Avatar
Might it jus be easier/cheaper to re-gear it and get an LSD?
Old 10-13-03, 11:47 AM
DIrEctQL
DIrEctQL's Avatar
I went 150 mph in my automatic SC300 while Kevin (lexcoupe) went 155 mph in his manual SC300.
Chris
Old 10-13-03, 12:55 PM
GSXtreme
GSXtreme's Avatar
Re-gear it??? Hmmm that sounds like the best way. But I didnt think you could do it with these rear-ends...? Who could do something like that? Has anyone ever done that before????
Quick Reply: 2JZGE Boost questions...
