98+ Valve Cover Gasket Replacement
6th Gear
I have been searching for a tutorial on how to change the valve cover gaskets for the 98+ models but keep finding either LS/GS tutorials or pre 98 SC tutorials.
Im sure i could figure it out with these existing tutorials but I wanted to see if anyone knew of a good write up for the later SCs.
6th Gear
6th Gear
Update: I took apart most of the surface level hoses and wiring to get to the valve covers, Except the wiring harness for the coils/injectors is still connected to a plastic inlet on both sides of the engine. I believe both sides of the wiring connect to eachother in the middle of this plastic inlet and I cannot figure out how to get the wiring disconnected/loose enough to make room for removing the valve covers.
Any tips?
plastic inlet connection (grey insulation to black plastic - middle of picture)
Driver side
Passenger side
Any tips?
Driver side
Passenger side
PjLex
07-29-11 06:18 AM
ohiois350
10-30-09 10:32 AM
