R12 to R134a (SC300/400)
I have a car that is running R134 originally was R12 it works well. No components changed. Cooling capacity is reduced somewhat though that may be an issue for you. Can you buy R12? In California it's easy enough to find.
From my experience nothing blows colder than R12 in cars.
Wow compressors have gone up. I used to tell people don't mess around with a used compressor but now the cheapest looks like over $400. If you find one, make sure you flush all the mineral oil out and replace with PAG oil. The evaporator pressure control valve probably isn't set optimum for R134 but seems to function ok if built for an R12 system with R134 in it.
Other than that you'll be needing an R134a compatible compressor, all of the A/C system components in a 1992-2000 SC300/400/Soarer work the same if you still have R12 or if your car was/will be converted to R134a or came with R134a from the factory... with one minor exception being the rubber seals at each service point in the system. Those seals can all be changed-- it's just labor (yours or a shop's labor). The R12 compatible O-ring seals are incompatible with R134a. Consider it a full system overhaul job.
So yes you can salvage those junkyard A/C lines and re-use them if they are still in serviceable condition. Just remember that you'll need to buy a kit that upgrades all the A/C system O-ring seals to the new 134a compatible type and of course you'll need R134a compatible oil for the system (I believe Denso sells this).
Actually the only thing that makes a R134 compressor compatible vs R12 is they are shipped with pag oil instead of mineral oil in the units made for R12. You can flush them and all is good, there is no difference in the compressors. And I have converted many systems and yes it is best to change orings where you can or have broken the connection but it’s not imperative. Not disagreeing but no need to change every connection if you haven’t broken it loose.
Not having to replace the entire compressor or every o-ring makes converting to R134a MUCH easier! Then the same test dye can be added to the system when adding the new PAG oil and R134a to see *IF* there are any leaking o-rings which can be replaced by the newer types, correct?
Roger, thank you for bringing your expertise into this thread! Your A/C knowledge exceeds mine and I learned something new
I was not aware that it wasn't required to change *every* o-ring in the system as I'd been taught. Same with the compressor-- I was under the impression that internally the ones used for R12 were a little different from the ones sent out for R134 applications, which apparently is not the case at all.
KahnBB6 (07-12-22)
Roger,
When I bought my '93 sc300 several years back and at that time I was calling on shops and they ALL stated that it would be in my best interest to use the factory valve. Boy was it expensive even with my 20% discount. I just wonder if anyone had luck with the aftermarket valves. I replaced my whole system with OEM and was able to get a huge discount on everything except the valve which came from Lexus.
Bill
Bill
Roger,
Bill
Bill
Roger,
Have been out of town for a few days and running late answering my mail. The valve I had replaced was the second one and with my 20% off at the dealer here in Mobile was over $500.00. That was why I was asking if anyone had used an aftermarket one and if they had good luck with it. Would love to know.
Bill
Bill
4th Gear
What are the sizes of the Adapters I need? I ordered adapters from Amazon and the Low side fits but the High side is the same as the Low side so it was too big...
Any help would be greatly appreciated... Ok
