99 sc400 seems stuck in gear at stop light
99 sc400 137k. I have only put about 1500 miles on this car bought from original owner that always had it serviced at lexus. They did a good job of keeping all receipts
Car mostly sat the last 4 years until I purchased it
Twice recently it seems it doesn't come out of gear at a stop light and lunges
Fluid level seems right
I did not see any receipts for a transmission service.
I have been reading a little about that, wgats the proper way on a car that age that has been sitting. I know it takes T IV fluid
Rcreegan (08-16-22)
Depends on your budget and tolerance of down time. Buying a spare (hopefully tested/rebuilt) can be $500-700 or more.
Removing it and sending it out for testing/repair can be around $200 but will be 7-10 days turnaround.
I used SIA for this service. Others have used Tanin.
https://siaelec.com/product/lexus-sc...repair-return/
That radiator looks to be on its way out, so don't assume all the maintenance is up to date.
Leaking capacitors in the ECU was my first thought, too. Maybe bad shift solenoids or a clogged filter. I'd be surprised if old fluids can cause that issue, but you never know.
