View Poll Results: Need advice
Multiple Choice Poll. Voters: 1. You may not vote on this poll
Need advice
1st Gear
Need advice
Can someone help have 97 sc300 I washed motor off and it started missing not wanting to take fuel as I was driving the cats started to glow punched hole threw it and put new o 2 in rise off manifold and down below so had no power on way home and second cat was glowing punched it out still ran bad I put new wires cap button crank sensor and was training to put cam sensor Butt Cant find where it is ,but anyway I can not get car to run like it should any help or ideals would be greatly
Hello,
Any Check Engine Lights?
There is not much that can cause a Rich condition, and since the whole engine doesn't run right, it is not isolated to one or two cylinders, you likely have issues with O2 or MAF sensor, or the ECU. I am not sure if your car has OBD2 port, if it does, check Engine Live Data, look for MAF, O2 and Temperature sensor readouts, and for Fuel Trims, and post the readouts here.
P.S. Punching the cats out when the car clearly doesn't run right, that's gotta be one interesting diagnostics method..
Hope this helps and best of luck!
