C/R with TT pistons/hg on NA motor
Old 10-26-03, 05:04 PM
motorheaddown
motorheaddown's Avatar
O.K... more food for thought.
Grant (mkiv mailing list) and I measured piston squish a few months ago, and the measurements yielded similar results.for the GTE motor (~0.062") and GE motor (~0.058"). Based on those measurements, I have a question. With the TT hg compressed to 1.35mm, it's clear that the TT hg accounts for most if not all of the squish clearance. The NA hg, however, is only 0.3mm, but the GE squish band is approximately the same as the GTE motor. So where does the GE motor make up the difference? Are the NA pistons shorter than the TT pistons at the squish band? Or does the NA head have a machined squish band that's receded into the dome?
Hmm... kinda makes ya wonder.
-scott
motorheaddown is offline
Old 10-26-03, 06:45 PM
awj
Bluegr*** Performance
awj's Avatar
The difference is in the dome of the combustion chamber yea? So how about TT pistons on a stock GE head gasket thickness. What is the cr there? Since we are crunching #'s.
awj is offline
Old 10-26-03, 07:13 PM
motorheaddown
Just for giggles, why don't you give it a shot? You have all the information you need to figure it out in this thread. I'll let you know if you're correct.
My point is that a very thin hg on the GE motor yields the same squish as the GTE motor. That's important for two reasons:
1) It's clear that a 0.060" squish is the Toyco design spec independent of compression ratio
2) It says something about the geometry differences of either the dome or pistons for the NA and TT motors.
I severly doubt that the squish difference is made up by machining it into the NA dome. It's just too expensive to produce. Consquently, the only other option is that the NA piston is shorter from the rod wrist pin to the top of the squish band. (You following me here?) If *that's* true, then using a TT hg with TT pistons on an NA motor should get the right CR *and* proper squish.
Think about it...
-scott
Old 10-26-03, 07:29 PM
awj
awj's Avatar
Think about it...
-scott
Sure ting. Eh, the ge heads are cast different. Who said anything about machining? Also, machining is a normal end operation in all heads, from the factory or on a rebuild. The stroke is the same in both motors is it not? It came out around 9.5:1 way back if I recall correctly. I don't have the volume of the ge head handy though.
awj is offline
Old 10-26-03, 07:42 PM
motorheaddown
I think you're confusing squish with clearance volume. The GTE and GE blocks are identical; the rods are identical; the domes and pistons (i.e. clearance volumes) are *different*; but the squish is identical. The dome and piston account for differences in CR but do *not* explain the identical squish measurement. Consequently, either the squish is machined into the NA dome, or the NA pistons are shorter from the wrist pin to the squish band.
-scott
P.S. I get 9.44:1 with TT pistons and an NA hg. However, if my theory above is correct, using TT pistons with an NA hg would make the squish *very* small.
Old 10-26-03, 08:10 PM
awj
awj's Avatar
Oh. Thanks man.
awj is offline
Old 10-27-03, 06:20 AM
Lex Luthor
Lex Luthor's Avatar
Careful Scott...
Lex Luthor is offline
Old 10-27-03, 07:10 AM
motorheaddown
Originally posted by Lex Luthor
Careful Scott...
Oh... I'm very careful. You should know that by now.
This discussion isn't about engine internal strength; it's about geometry. I'll bet a paycheck that the rod bearing to wrist pin *geometry* of the VVT-i rods are identical to the original 2jz rods, but that's not my main point. The issue is one that centers around equal squish with different hg thickness' on the NA and TT motors.
If someone can help explain how the NA motor makes up for squish with a thin hg, then I'm all ears.
-scott
Old 10-27-03, 09:08 AM
awj
awj's Avatar
I thought it was clear...
you answered it yourself, yes?
awj is offline
Old 10-27-03, 01:27 PM
RSTSpeed
RSTSpeed's Avatar
Not to go backwards, but...
I RST, the 1JZ has half a litre less displacement and problems with parts availability here, stick with the 2JZ, and yes the TT pistons fit into the GE block without oil squirters.
Yea sorry... I was *butt*-backwards - had the 1JZ and GTE confused. Thanks.
Originally posted by Fred Smith
I believe the Supra manual states that the GE and GTE block, crank and rods are identical.. not sure about the head. If the head is the same, then with a set of GTE pistons, I believe you just built a 2JZGTE?
Wtihout the squirters, yep. Oh, no the head is different dog.
So if you swap the TT pistons, head, and hg into the GE, THEN you have built the GTE but w/o squirters - right or wrong? Either way, does that setup creat the correct (same) CR and squish as the GTE?
*EDIT* Also, should you even consider getting doing the actual GTE swap unless you're shooting for HP > 500? What HP point should oil squirters become and issue?
RSTSpeed is offline
Old 10-27-03, 02:19 PM
Lex Luthor
Lex Luthor's Avatar
If I were you I would spend like a week using the search engine with the contents GE, GTE, and turbo, there is much to learn grasshopper. There is no advantage really to swapping the GTE head onto the GE block (other than more cam and turbo manifold options)...matter of fact the GE head can be made to flow better. So you would swap the pistons and head gasket into the GE long block, and use a turbo manifold designed for a GE head (GTE manifolds won't work incase you were going to ask ), clear?
Scott, I should have assumed you were referring to the geometry of the rods and not the strength. Would really like to know what size chambers the GE head has, and if the GE VVT-i head is any different chamber-wise. Should've cc'd that bad boy when I had it apart...
- Jon
Old 10-27-03, 02:54 PM
RSTSpeed
RSTSpeed's Avatar
lol, ok thanks... sorry if I'm getting on anyones nerves.
RSTSpeed is offline
Old 10-27-03, 08:40 PM
motorheaddown
O.k., time to wrap this thread up.
Lance Wolrab has one of DaveH's NA heads, and he inspected the dome geometry. Turns out I was half right. The NA head has a squish band machined into the dome that's about 0.023". That means the NA piston also contributes 0.025" to the 0.060" squish.
Bottom line: An NA-T motor with TT pistons/hg gets you a 8.62:1 CR and a squish of about 0.090". That's about half the squish I'm currently running, but it's still 0.030" over spec.
Case closed.
-scott
Old 10-28-03, 08:07 AM
DaveH
DaveH's Avatar
Looks to me like it's time to machine that 0.023" squish band off of the NA head.
DaveH
DaveH is offline
Old 10-28-03, 02:40 PM
motorheaddown
DaveH
Hmm... interesting thought, but taking out the squish that's receded into the head means that you also reduce the clearance volume by ~3.3cc. That basically negates the contribution of the TT piston dish (4cc) bringing the CR back up near 9:1. Nothing a little meth/water injection couldn't handle.
-scott
Quick Reply: C/R with TT pistons/hg on NA motor
