C/R with TT pistons/hg on NA motor
#31
After you machine the head surface, then you do a valve job that sinks the valves back into the combustion chamber a ways, getting some of that head volume back, along with allowing you to use those Crower cams without the lash caps.
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
#32
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Hopefully, I'm wrong. Someone care to check my reasoning?
I guess you could hardface the cams, but I'm not comfortable with adding material to the lobe.
-scott
billydpowe
08-06-11 01:10 PM
