sc400 cold air intake
Old 10-23-03, 10:08 PM
SC400_408
SC400_408's Avatar
Hey Ali have you taken a look at a 96 yet? Yeah it just looks weird I tried to fit a pipe on but is won't hold. When you take out the airbox the end part is plastic. Not like the 92-95 its metal.
Old 10-24-03, 12:06 AM
xBlkGs430x
xBlkGs430x's Avatar
you can't get an MAF adapter for the 96 and add the pipe to the addapter.
Old 10-24-03, 07:31 AM
jmecbr900
jmecbr900's Avatar
Great job Ali. Way to come up with something on your own. It looks like a good job in putting it in.
I also want to make one suggestion regarding the water/hydrolock issue. It is very much an issue that can be easily resolved. All you have to do is buy a bypass valve. AEM makes a very good one. It only costs like $30, but it will totally protect you against ingesting water up into the intake. Splashing water should not be a problem unless the filter is totally exposed to the elements. If it's where I think it is, behind the foglight in the wheel well, he's not going to get any water unless he drives thru a large puddle.
I personally would buy the bypass valve that way you wouldn't have anything to worry about at all. Look at it this way...you'll have a CAI with less than $50 invested. You can't beat that.
BTW, the AEM bypass valve SAYS it won't work in other CAI's that are not AEM, but that's BS. I put it on my CAI from Place Racing and it worked beautifully. They make a 3" and a 3.5" one. That's all that matters.
It was tested in a magazine not too long ago on an NSX. They built a long "CAI" that was outside the car and dipped inside an aquarium. Obviously they were trying to see if the valve would let the water up into the intake. I DID NOT. Even with the car under load on a dyno, and the filter totally submersed it didn't let it go up into the intake. Kinda like a broken straw. It's really a simple concept. Wish I'd of thought of it....I'd be a zillionaire now.
Good luck and great job on DIY.
Old 10-24-03, 06:43 PM
SC400_408
SC400_408's Avatar
Hey Ali, yeah I asked around and ppl were saying the MAF adapter wouldn't fit. So yeah, I'm eager to do this mod but kinda stuck .
Old 10-24-03, 10:32 PM
dartdoc1
dartdoc1's Avatar
I'll take one have any pre-made oes available I'vegot the $15.00 to spare anyway looks good
Old 10-25-03, 03:48 PM
xBlkGs430x
xBlkGs430x's Avatar
can someone post a pic of the 96 sc intake...im not sure what the difference is.
i just ordered the AEM bypass valve. thats probably the best way to go..thanx for the advise
this is a very easy thing to do...i don't have any premade ones. just find a shope that can bend the pipe for you like a muffler shop and they can do it...the 3" to 3" rubber connector can be found at most hardware stores.
Old 10-26-03, 05:18 PM
cloudnine
cloudnine's Avatar
http://www.racingsportsakimoto.com/prod_spiralflex.php has flexible tubing that might eliminate the need to have the tubing bent.
Mike_1GO
09-18-13 05:34 AM
pwashking
05-07-12 11:18 AM
rwdanthony
SC400 / 300 Classifieds
11-17-08 02:54 PM
pylee257
Performance
26
06-07-07 06:11 AM
binelus
GS - 1st Gen (1993-1997)
05-17-04 01:30 PM
Quick Reply: sc400 cold air intake
