Need some advice: non-VVTI 1UZ into a former VVTI SC300 roller
3rd Gear
So, long story short, I have the chance to pick up a very good condition VVTI SC300 roller. How much trouble would it be to throw in a non-vvti 1UZ into it? What would I need other than the motor(would the stock SC300 auto trans match up?) and accessories?
Your non-vvt i engine would probably need to be 95-97 obd2 if I remember correctly.
I would browse the build section and look at sc400 1jz and 2jz swaps to get an idea of what you may need, Toyota diy as well that can give you an indication of what part numbers are similar.
edit:
https://www.*******.com/
I'm not sure about the transmission (I'm sure a quick search on what autos came in what will help) - however, I do know that you'll need all of the accessories, ecu, wiring harness, some lines (PS, vacuum, etc) all from the 1uz car because a lot of those are different between motors in the same chassis. Custom hoses, lines, etc are easy to have made and I believe there are plenty of aftermarket alternatives. In a simple answer - yes, you can do it, but you'll want to find the most complete swap you can that includes all of these things to try and make your life as easy as possible without having to get too creative.
3rd Gear
Thanks you all. I still haven't decided if it will be worth it. I have a completely gutted 92 SC400 for a doner. Just trying to figure out if it would be smarter to just take parts from the shell and move it 92 and skip the hassle. I will just have to put a new transmission in the 92 which I already have.
That may just make your life easier... If one shell is particularly nicer than the other that always helps make up your mind on what amount of work is worth it to you!
3rd Gear
Now that I think about it. What would I need to just put a new vvti 2JZ in the 98 SC300. Would a VVTI 2JZ with wiring harness and and ecu work from a GS300?
I see a 2001 GS 300 at my local Pull-A-Part
It seems so hard to get a complete 2JZge with harness and ecu together for a “reasonable” price. What would be my options? This is just a project, and not a daily. I would want to open the engine up, have it checked and change rods and freshen up all the seals anyway. The aim would be to Turbo it for a mild build.
DrLex
Performance & Maintenance
17
03-13-12 08:46 AM
