What is this noise? Bad transmission mount? help
Old 08-22-23 | 10:11 PM
Cristobal's Avatar
Cristobal
6th Gear
Default What is this noise? Bad transmission mount? help
I had the original transmission fail on me and was pretty quiet. I found a used one on the junkyard and mechanic installed it, now its making this noise what could it be? I had the mount replaced on the old transmission 50k miles ago
The faster I go the more noise it makes
Video: https://www.youtube.com/shorts/l71dVklv8uk
Old 08-23-23 | 05:00 PM
2013FSport's Avatar
2013FSport
No clue. Get it up in the air and see if anything stands out. If you make another video, put it manual mode and show the tach, speed, and gear. That would be helpful.
It sounds to slow for engine or driveline, almost as if its valve train which is 1/2 engine speed. Open the hood and listen. Maybe shove phone under hood and drive?
goose300
09-22-19 01:28 PM
Andyk803
IS - 1st Gen (2001-2005)
12-13-14 08:20 AM
VDMTom
04-20-14 10:12 PM
quaiduhm
SC- 1st Gen (1992-2000)
07-30-11 09:57 PM
nysupraman
Performance & Maintenance
14
12-09-04 09:59 PM
