GS400 Superchargers what have you done to upgrade over 8lbs of boost
Not sure what to say. The difference in climate can play a significant different in the amount of boost. If its humid and hot that will make a noticable difference that cold and dry. Plus it depends where you measured the boost at. It will definitely be higher near to the S/C as opposed to measuring it right near the throttle body
Originally posted by jmecbr900
gsHunter: Yes, I have the exact same pulley TT has; the 3.12". The difference is that I'm only seeing 6lbs of boost vs TT's 8lbs of boost. Where the difference comes in??? I don't know. I still have the 310's because my system was running really rich vs TT's which was the opposite. Reason??? Don't know that either.
I'd be more than happy to share any info that would help you in anyway. Just ask.
I don't think I'd try running more than 9 lbs/boost on stock compression/motor. If you are ready to build it up again if it blows though go for it!
Originally posted by Mr Johnson
Look at the intercooler, especially the endcaps. From my stage II to stage III update got a brand new intercooler core and it dropped much less pressure than the old one.
I don't know. I honestly think that maybe the problem lies in the crank pulley size. I don't think I have the same size as some of the other people. That's all I can figure.
BTW, I wouldn't run more than 9lbs of boost stock either. I think the compression is too high stock to go above that. I think the internals may hold it, but I think detonation will be a bigger factor. I personally aint trying it.
Jaime, you say you ses 6 lbs of boost, do you 'see' it on a guage in the car? Not wanting to overlook the obvious, maybe the guage is flakey?
Maybe you're right though. What do you think? I guess I can go to another dyno I know has a device to measure the actual vaccum.
Dude I barely know how to spell supercharger so your guess is as good as mine, but I do know about Occam's razor (the simplest explanation is usually right).
gshunter, I have plenty of room with my 370's with what Im running now, I have no doubt that I could go higher in boost with these injectors not being maxed out. I have been tlaking with jamie back and forth since we both started this project, and we have had some really strange difference in outcomes with pretty much the exact same set up. His tuner said that his car was running rich throughout the entire band(if Im not mistaken, Jamie, correct me if Im wrong on this).......My tuner said I was running out of fuel at the top, I could see on the dyno sheet where I was running lean and the power was dropping off.....this is with both of us using the 310's the kit came with. Keep in mind, he is on ly seeing 6 lbs of boost, so this might account for that.
I went up to the 370's just to eleviate the chance of detonation at max boost, the 370's solved the problem, but they didnt give me much more power....which I was hoping to get with adding feul up top where I was lean before. They do give me the peace of mind of knowing I wont be lean when really pushing the car hard, ecspecially with the weather changing colder now. RMM would have included any size injectors that I wanted with the original kit at no extra cost, I just didnt know what to go with at that time....trial and error.
Just uploaded my "old" dyno chart from the first few pulls with the "7lb" pulley on.
https://www.clublexus.com/gallery/sh...cat=500&page=1
Notice on the bottom that the A/F is almost dead straight once it's hammered. Notice also that when the car hits the rev limiter, the A/F kinda rises slightly. This is just before our last run which I ran a 352.8. For whatever reason, on my car with 310's it's running rich. In TT's car, it ran slightly lean on the top end. This is kinda odd since we both have the same identical setup.
I was so ticked off that I didn't hit 8lbs of boost with the smaller pulley that I left the dyno and forgot my printout. It showed slightly higher HP/TQ readings, and the A/F was identical to this one....flat @ 12 all the way thru.
We'll see next time.
