Which spark plugs for 2022 IS350?
Hello,
So recently was reading about spark plugs how they have different types and might improve performance and reliability of the car and looks like most people say that NGK Iridium Spark Plugs are the way to go.
So I was planning to get a set but there is so many different ‘numbers’ so I’m not sure which one fits my 2022 IS350 FSport AWD? I always thought that all spark plugs are build with the same size/standard.
Have you tried searching for something like "IS 350 spark plugs"? NGK makes spark plugs for a lot of different makes and models; simply searching for their products is not a good way to look.
Denso makes the original equipment spark plugs. The part number is - 90919-01263.
If you don't like the original plugs, why is that?
https://www.proimporttuners.com/part...plugs-set.html
If it comes to OEM plugs - i mean I don’t mind using them but if there is better alternative that might help the engine/performance and they are better quality, why not? Unless there are some drawbacks using Iridium aftermarket spark plugs then i’m ready to listen
Thanks, i forgot to update but yeah I found them on website:
I used NGK Laser Platinum spark plugs as replacements on my Mk7 GTI, and it felt exactly the same to drive as it did with the OE plugs (which, I believe, were also manufactured by NGK - just with a VW sticker instead of an NGK sticker). To me, that's a good thing. Spark plugs really come into play if you are tuning the car or boosting it somehow. Otherwise, the plugs by themselves probably won't do anything.
Nexus713 (11-30-23)
Nexus713 (12-04-23)
AdamProve
Performance
24
09-29-20 08:50 AM
jbone29
08-17-12 08:27 AM
