Headers for V8 cars, Please read
#31
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
Originally posted by jmecbr900
I'm in, but where is this "commitment" place everyone talks about.
J....just add my name to the list as "in".
Originally posted by DaveGS4
If you are ready to commit your interest in these headers, send a private message to JBrady with the following information.
Screenname:
Email Address:
First & Last Name:
Street
City:
State:
Zip:
Phone
Year & Model of your Lexus
These details will be kept confidential.
If you are interested in participating please send a private message to member JBrady (click here to send message )
Screenname:
Email Address:
First & Last Name:
Street
City:
State:
Zip:
Phone
#33
Jaime - if you're "in" you commit by doing like it says in the original post (pasted in again below).
I'm now officially "in".
#34
Those C's headers are beautiful... But before jumping in, will these headers be equal length? How hard is it to remove the headers? It looks tight in there. I will need to know these question before purcahsing them. Thanks.
Also, I live in California but doubt the smog guys would even notice. It shoudn't even affect emissions.
It might be a little louder since the cast iron manifold is excellent at holding in noise.
-Jeff
-Jeff
#35
-Jeff
-Jeff
Yes, the Cs headers "look" pretty but if you look closely the tubes actually interfere with each other and that makes for a sub-optimal "working" part. The pictures are not to indicate actual final look just an idea of concept. I suggest you re-read the entire first post and in fact this entire thread as I have addressed the tube length and the installation unkowns. Quickly, no, not equal length nor required for the power we are targeting. Equal length primary tubes are only effective in a small RPM range. The rest of the time it is all about flow, velocity and scavenging. For any value the equal tube style would need primaries neary 3 feet long each and that obviously is not going to be a shorty style header. The shorty design should do very nicely just like the shorty design for the Tundra for which the dyno chart is shown. Installation is not easy, and as yet an unknown. Also, the stock manifolds are tubular not cast iron. Here is a link with pictures of the stock manifolds:
https://www.clublexus.com/forums/sho...hlight=air+box
#37
I'm in too. If he can make longer length primaries I'd be willing to pay a bit extra. I'm making custom downpipes/test pipes anyway so to me it doesn't matter. I have full TIG welding capabilties here.
#38
#42
Forum Administrator
Originally posted by Lexkost
Will they be smog legal in California ?
#43
Forum Administrator
Originally posted by 3dog
with the headers and a good exhaust will we also need an air intake to maximize the benefits. ivan
#44
I just think that equal length headers will produce more top-end power without sacraficing any low-end power. That's why I asked about equal length headers.
If your local craftsman can produce headers with welds and bents as good as those C's headers I'll be very very impressed with the work. Well, I'm in if, the headers install do not require removal of the engine.
-Jeff
BTW, Your right about the headers. I thought they were cast iron manifolds. My bad.
-Jeff
Originally posted by jbrady
Jeff,
Jeff,
#45
-Jeff
-Jeff
While I agree it is of course theoretically possible to produce a higher power exhaust header/manifold by optimizing the length to the RPM window targeted... the real world situation shows that the added expense, increased installation difficulty and deviation from factory emissions configuration make long tubes a poor choice for 99% of road cars. Also, the KEY to making power is optimizing flow. This a accomplished by creating the lowest possible pressure at the exhaust port during the last half of the exhaust event when in cylinder pressures are dropping rapidly and the pressure differential becomes most important. Long tube headers isolate the individual ports and create a resonance tune effect dictated by tube length and diameter. This tune only happens in a small RPM window. Above and below that RPM the main effect is due to velocity scavenging. Velocity scavenging is the key to the HFVS header and is designed to enhance the effect from low to high rpm. The performance difference between the HFVS and a very well designed ELLT (equal length long tube) design is unlikely to be noticeable from the drivers seat. A poorly designed ELLT will actually hurt performance in various RPM ranges compared to even the FACTORY manifold
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
I for one would be very unhappy to spend big bucks and make all the sacrifices needed for ELLT only to have a car that is LESS responsive in most driving conditions.
So, for an expert like yourself the ELLT is maybe a reasonable choice but I wanted everyone to understand they are not sacrificing by using the HFVS design with a good cat back secondary system (key to the overall performance of ANY wide RPM operating system).
