Headers for V8 cars, Please read
#61
Re: how bad is that?
Originally posted by fireballs gs400
curious on the size of the problem?
https://www.clublexus.com/forums/sho...highlight=flow
Here is a picture of the stock manifold looking down from the port into the "log". Notice the overhanging sharp edged metal. This goes completely around the port even though just one edge is clearly seen here:
#62
So if I'm following this....the design you're working on will improve on the severity of the bend in order to help with velocity of the exiting gases AND also have a bigger diameter to improve volume?
Is this why the design has to be careful not to be too radical otherwise we run out of install room?
Just trying to make sure I'm following.
#63
The pipe diameter will be slightly larger than stock but without the horrific bends and sharp edges at intersections and merges.
Look at the above picture and note the sharp edges inside the manifold that protrude into the gas flow. The turbulence caused by this type of aerodynamic interference functionally makes the passage smaller. It also converts flow energy to heat energy. You can see this by looking at the factory dyno picture below and noting the hot spots at each intersection. This loss creates a flow restriction AND has less energy to scavenge. By improving these points we can achieve a significant improvement in flow capacity without lowering velocity or converting flow energy to heat and backpressure.
#66
Re: Re: headers
Originally posted by DaveGS4
I don't know for sure (and no one really does since these headers are new), but I'd guess the effect would be similar to having an intake only or intake + exhaust. They compliment one another and work better than they do individually. Of course the 'combination' of mods that will work best is unknown at this point.
I ask because I already have the L-Tuned exhaust which, while more free flowing, is certainly no cat back. Can I expect my current exhaust to work well with these headers, or if/when I sign up for the headers am I implicitly also signing up for a new exhaust and high flow air intake to realize the gains?
Sorry if this is a dumb or previously answered question...
#68
I'm in. I can provide dyno results as well for you. I'm installing these with test pipes and full exhaust. I have a bone stock GS400 with an S-AFC II in it. I have dyno'd many times stock at around 240-244 whp.
#69
Who was it that was questioning your expertise?????
Expert in my book. I understand and SEE what you are refering to. Excellent write-up.
I'm still sold and in on this.
#70
Re: Re: Re: headers
Originally posted by SCWells72
Scanned the thread to see if my question was answered, and this is the closest I could find, so I'm going to ask my question. Is the expected ~20hp/20lb-ft rw gain already in conjunction with a full cat back and/or intake, or is that before any other modifications?
