Torque Specs for Transmission Pan bolts.
Can anybody provide me with the torque specs for the bolts that hold the transmission drain pan? they are 10mm bolts and i think there are like 18 of them.
Thanks.
Thanks.
per
http://diy.icydesigns.com/article/22...luid___Filter/
Install the drain pan and torque the 19 bolts each to 65 in.-lb (75 kg-cm, 7.4 Nm), 65 inch pounds not foot pounds.
Install the 14mm drain plug with a new gasket, part #35178-50010. Torque it to 15 ft-lb (205 kg-cm, 20 Nm).
Scott1258
RX - 1st Gen (1999-2003)
12-04-17 04:34 PM
