Looks great Is that a 6000k bulb in there? Also do you have any pics of the cut-off beam against a wall? Did you get the autoleveling mechanism working on your set?
Originally posted by FutureGSorIS Looks great Is that a 6000k bulb in there? Also do you have any pics of the cut-off beam against a wall? Did you get the autoleveling mechanism working on your set?
yeah it's 6000k ...i didn't finish the other side set so i did take the cut-off beam againt the wall...and no i didn't used the autoleveling cuz i don't have factory hid...
Hows the cutoff against a wall? It looks kie it would be a liitle crooked. U have to line up the inner 3 lenses straight acroos so you get a even cutoff. On yours it looks like its a little diagonal it should liike like this. Did u adjust them yet?
