anyone turbo GS running Trust E-manage
I'm going to install my E-manage today. Anyone here ran that with the turbo motor can gimme some feedbacks? I'm gonna take a day off to programme that sucker.
If you have GS300 it is perfect for boost since you can map it for boost. YOu need to either link it to the E-01 with the special boost wire, or buy the optional boost sensor and wire. THen check the greddy boost pressure sensor option in the parameters menu and then switch the scale on the addition injector map to greddy sensor kg/mm. Voila, you can now map for off and on boost perfectly for up to 35 PSI. Works better than any piggyback I have ever used.
