speed chip gs400
does anyone have info on this item? i have seen it on ebay? any thoughts or testers?worth it?
speedchip aka performance chip?
thanks
loren
thanks
loren
Definately a scam. I've never seen anyone be able to reprogram the Toyota Multiplex ECU's and if so it'd be super mega expensive. Try getting an S-AFC and some dyno tuning instead. This is especially important with an intake (see my other post).
The S-AFC won't s\retain your setting becuase of the ECU's "learn" feature. You would require something that would onvolve a "closed loop" system, aka stand alone.
The closest you could get would be the SRT intake setup w/ ecu incldued. The only drawbacks maybe t hat depending on your future mods, you may not be able to take full advantage since the ECU's are tuned for a specific setup. Now, on the other hand, I have personally reprogrammed SRT ECU's for people in the past, depending on if I had a program that contained similar mods for customers.
Take that info & go into the world & prosper my man!!!!!
Chow!
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
Originally posted by lexlyf
Sure you could reprogram it. It's called a "stand alone" ECU!! lol!!
