Last edit by: IB Advertising
Browse all: Lexus IS Engine and Powertrain Guides
- Lexus IS GS: How to Replace Spark Plugs
Step by step instructions for do-it-yourself repairs
Spark Plug Change for GS300
#121
Got the wires and the plugs, but if I have the denso wire set without the connectors can I use the ones off the old wires. The connectors that I'm talking about are the one that have the letters on them.
#123
I just bought the denso wires from rockauto but they didn't come with the clips that snap into the connectors, can I remove them the clips from the old wires? Any help is appreciated, I currently have my car torn apart in the garage because I'm doing the timing belt. I wanted to do the plugs while the valve covers are off.
#124
Actually, I was incorrect the connectors do come with the wires. The snap on to the coil packs. You should be good to go.
#125
Paying respects, not sure how many times i read through this but finally got done with the sparks and valve cover gaskets. no problems except all the oil i had to clean up lol. oh definitely glad I read that the clips break because I tried to be careful and broke all of them but had replacements already
#126
#127
okay guys, i just change my plugs with v-power $2.29 each... my car was running fine before, but i figure why wont change the plugs... now my car is sputtering.. HELP PLEASE! ASAP!
#130
I have always been a fan of doing what the manufacturer suggest when it comes to plugs. I used Denso twin ground, I think it was DENSP50745. But, it could also be other things as well like the connectors (to the coil packs) and/or the plug wires. If your car was like mine, the connectors were extremely brittle. In addition to the connector breaking up, the wires can pull out of the connector some exposing bare wire that can short out. I would start with those first: OEM plugs, plug connectors and plug wires. You can get the connectors on eBay for about $15 for 3 and a set of wires for about $30.
#131
im gonna be changing out my plugs in my 98 gs300 tommorrow, with 150k my qeustion is should I buy the wire set with or without the coil boot? I dont see alot of guys on here saying that they changed those out so im curius because it a $20 diffrence Thanks
#134
Here are the part # for the clips. 1953950010 = #1 coil (front)
1953246010 = # 2 coil (middle)
1953970010 = #3 coil (rear)
