Supercharger Install
Success
Success!!!!!!!!!!!!!
Started her up and it is warming up getting acclamated to it's new found muscle. Still need to install the Apexi unit. SC is a bit noisy though I am told it will quiet down considerably over the next few days. Checking for leaks at the moment. I still need to tidy up a few things. The oil drain hose they supply is a bit short so I will replace it with a longer one. Bad thing is-the SC needs to come out to access the hose.
I also need a longer bolt for the tensioner. They supply a belt, but the wrong size belt for this pulley. They said that I NEED go BUY a shorter belt or BUY a longer bolt for the tensioner.
BTW- no oil light. Shorting out the sensor means to run a single wire and place both ends of the wire into the sensor connector which shorts it out. This fools the computer into thinking the sensor is reading normal. Instead I ran a nice u shaped piece of metal which slid nicely into the sensor and taped it all over to secure it in place and to keep grime out..
Still much work to be done but so far so good. Thanks for the kind words guys.
Lee
Lee
I would agree. 5k and not the proper belt. Plus they know about it. They bought or made 25 of everything initially. All of these components were for the stock pulley, so they do not have the correct items for the higher boost pulley. That is their side of it. Still...is a 15.00 belt asking too much in a 5k kit?
Also, I spoke with XSengineering for tuning. Come to find out they say I need a subcomputer AND and a O2 clamp on top of the APexi unit for tuning. 700.00 or so for parts not including the dyno session.
WTH IS THAT. Their claim is that the APexi unit does not do a proper job. So do any of your out there with SC, where did you get yours dyno's and did you run into something similar?
thank you
Lee
thank you
Lee
exclusive matchup
wow, congrats lee, that's some pretty fast install, and you definitely know what you are doing man, awesome, cant' wait till it's all said and done
honestly from what i have heard about rmm, they haven't really been that great in products anyway. somehow i am not too surprised about the wrong bolts, etc... i am kinda surprise that they just told you to get some other @_@
and about xs engineering, yeah they are always nutorously expensive for tuning cars. maybe they are good, but definitely pricey
EV ftw!!!
Congrats Lee on the new found muscle install in your car!! You make it sound like a walk in the park!
ON HOLD
I spoke with Swift again (always ready to help.,thanks Swift) today and this time they say that since my setup is the same as Jeff's , that they will ship out an ECU for $250.00 with one free update if the dyno shows it needs tweaking. Sounds good to me and no fussing with the Apexi unit (maybe for sale shortly). So the project is on hold for about 1 week which is what they need to make one and get it to me. In the meantime, this will give me time to take some more pics, fine tune and tweak the install and go over every nut and bolt once again for any loose ends.
I would love to install the headers on the Tundra in the meantime, but I swore to myself long ago-only do one project at a time,especially if one of the vehicles is down. I learned the hard way. Sucks having two cars and neither one running due to some unforseen install issue.
Lee
Lee
Originally posted by Pearlpower
ON HOLD
Lee
ON HOLD
Lee
Forum Administrator
Lee - just to set your expectations it'll get you closer! Assume you'll send a dyno sheet with air/fuel back to Mo for the second set of tuning?
I used Jeff's tuning when we moved the RMM SC from his GS over to mine and his needed more fuel than my setup did. Started basically at 337 hp and 294 tq. After a few runs and tweaks Mo brought it up to 363 hp and 314 tq.
Orbit9, yes I called Daniel I believe at SRT using the phone number on their website. Tell him Lee sent you. Say hi to Mo.
Lee
Forum Administrator
Was there any difference between the install such as injector size,etc..? Curious as to why there was such a drastic change if the kit is exact. I suppose every little bits makes a huge difference when it comes to FI. I should have the other ECU in about a week. At that time I will have it dyno'd and if it does not come into spec, send off the dyno with a/f to MO for fine tuning. I do expect this to take some time.
Lee
Lee
