no throttle vsc/vsc off lights came on
Old 06-29-04, 05:57 PM
lexoman
lexoman's Avatar
Unhappy no throttle vsc/vsc off lights came on
it started about two weeks ago, after leaving from a stop,no throttle for a few seconds and both vsc and vsc off lights,came on and went off,now it is happening alot very dangerous.i did a search but did not get a conclusive answer,looks like it might be the throttle position sensor?any ideas anyone?thanks
99 gs400 110000 miles
Old 06-30-04, 05:45 PM
Guru
Guru's Avatar
Yep TPS sensor most likely. THey are not that expensive and easy to change.
Old 06-30-04, 08:49 PM
JPI Racing
JPI Racing's Avatar
Becarefully though, There are two TPS on this engine. Also you will need a adjust it to 13% throttle when replacing this. It looks easy but it's not that easy.
JPI
Old 07-02-04, 10:52 PM
lexoman
lexoman's Avatar
well removed negative battery cable.left it off over night,problem has not been back,i could not drive more than 5 miles with out the problem.it's been three days?should i still replace tps?
Old 07-02-04, 11:34 PM
JPI Racing
JPI Racing's Avatar
If you have access to a scan tool, I would check it out to see if you can retreive any codes.
JPI
Old 07-03-04, 09:28 AM
lexoman
lexoman's Avatar
did that no codes.thanks
Old 07-07-04, 04:54 PM
lexoman
lexoman's Avatar
it's been a week,running like a champ,who knows
Old 07-13-04, 12:05 AM
Pearlpower
Pearlpower's Avatar
Most likely the Accelerator Sensor. Just a matter of time before it goes south. I replaced both the TPS and APS just to be on the safe side.
JPI, I swore the throttle angle is 14%, but it has been a month or so since I set mine prior to the S/C install so I could be wrong.
Lee
Old 07-13-04, 07:45 PM
JPI Racing
JPI Racing's Avatar
Lee
Do you have access to a lexus scan tool?
JPI
Old 07-13-04, 10:48 PM
Pearlpower
Pearlpower's Avatar
JPI,
I have scan software on my laptop with the appropriate cables to access the vehicle information such as O2 readings, throttle angle, etc....Works great.
Lee
Old 07-15-04, 10:44 PM
lexoman
lexoman's Avatar
well i replaced the tps anyways,my service manual say's to set it at 15.2% so i did,no probelms yet.
idle feels good with no air or lights on in 90+ weather.
az-dave
Performance
566
08-24-20 09:38 PM
DASHOCKER
Performance
39
08-28-18 05:10 PM
Zyro1214
03-15-15 01:55 AM
gs3213
10-26-11 02:32 AM
julian14
01-28-11 01:10 AM
Quick Reply: no throttle vsc/vsc off lights came on
