Lexus Mechanic Question: DIY Torque Converter install
I purchased a PI torque converter recently for my 99 GS400.
I'm thinking about buying a Service Manual and just doing the darn thing myself with the help of some friends.
My question is, Is this going to be much different than doing the same thing on say,...a Chevy or a Ford?
Sure, there's some electronics here, but, I was viewing that as probably being an unpluggable harness or connector. (or 2 or 3)
I've done a handful of TC replacements on older muscle-cars, done head swaps, carbs, intakes, and one main bearing replacement on a 327.
I think they call for 6.5 hrs of work for the TC installation.
Should I do this myself?? I've had 2 shops now quote me between $500-$590. I've only got one or two more places to check!
The job is not something that is impossible or anything, but the real bear is that you really should use a lift. You will have to drop the entire tranny to do it. You will also have to drop the entire exhaust from the manifold. It can be done if you lift your car up high enought. That's the tricky part. Lifting it high enough to get the tranny down may put you in a dangerous situation. Be careful.
Remember to also always use Toyota ATF only. It's very expensive and you will need more than normal because the new TC will take up a bunch being dry. That reminds me, you have to "prime" the TC BEFORE installing it. You'll fry it if you don't.
Good luck.
Good luck.
I'm going to be installing the PI TC this weekend in my garage. It shouldn't be too difficult. The hardest part is removing and installing the heavy tranny without a lift.
How do you prime the TC? My TC is used and has some oil in it, but I'd like to make sure it's primed.
G35x - RWD/AWD goodness
When you start to pour new fluid in you'll see it fill up, then quickly disappear. I put about a quart of fluid in on the used one for my Supra. You can stop adding fluid when it stops disappearing and stays around the level you saw the old fluid at before you emptied it.
Good luck and let us know how it goes.
The priming procedure is just like Overclocker mentioned. It's simply filling the TC with brand new fluid BEFORE you install back into the tranny. Be sure that it's flat on a level surface when you do it and again remember to only use Toyota ATF.
Good luck.
Good luck.
Anybody know if Redline makes a trans. fluid that will work in our trannies or if anyone has used something else besides Toyota fluid?
Don't want to take any chances when I do mine... thanks!
Originally posted by BA_GS400
I got quoted a $530 price today by a different shop.
So far, that's 3 shops, 1 was a Lex dealer,....all asking over $500.
I'll be a devil's advocate here and say.....This is a job folks. It's not as easy as it looks on paper. You have to drop the entire exhaust from the manifold, you have take out the drive shaft, you have to THEN drop the entire tranny, pop out the old TC, prime the new one, pop it back in, and reverse the entire procedure all over again. This is why most shops charge $500+ for this job. It's not rocket science, but it is uncomfortable and time consuming.
Even with the use of a buddy's shop and his lift, it took us a few hours to do this job. And he does this for a living!!!! AND we had every tool imaginable known to man. Trust me, it can be done at the house if you really want to, but it's not like changing out some plugs or something. It's a bit of a job.
Good luck and be sure to have the procedure outlined in your head BEFORE you start. You will be tinkering with a VERY expensive part of you car. If something goes wrong, you'll fry a $2k tranny in about 30 secs.
JPI
Dont let anyone talk you out of doing this yourself.If you have done a few in the past you wont have any problems.
Like was said before all you will need is a LONG extension or two and a good 3/8 universal.
Once the car is UP on four jackstands you will just use your jack to lower the tranny, unless you and your helper have strong upper bodies!
What sone people fail to realize is that if someone is mechanically inclined then they can pretty much work on any type of car.All rear wheel drive cars are pretty similar.Yeah there might be a few differences but all in all they're not too different.
Good luck and if you run into any problems feel free to ask.I'm sure the guys who have done them before will be glad to give you a hand.
Just because cars have RWD in common DOES NOT make them the same. It's obvious that you haven't attempted to drop a tranny using 4 jackstands. If you had, you would see it's far from "easy" or a piece of cake. That IMO is going to be one of the toughest parts of the install. It's going to be difficult to raise the car high enough with standard jacks. Working on a Lexus is far different than working on Chevy. Just because you have 4 wheels and an engine doesn't make it the same nor simple to work on one. Sorry, I totally disagree with such a generalized statement.
I've done my own, so I'll say it again.....it's NOT rocket science. So technically, you don't have to be a super duper mechanic to do it, yes. The issue with doing it in the backyard is that you have to figure out how to lift it up high enough to not only drop the tranny but then slide it out. If you can do that to start, then you may be able to handle the situation.
If I didn't have the access to a shop like I do, I would have definetly paid to have it done (technically I did because I paid for some of the job) rather than risking tearing up my $2k tranny. Ultimately it's up to you since it's your car and your money.
Good luck.
No disrespect taken.
Yes my gneralization was pretty broad, but it got the point across.
I'm fairly new to this forum and I dont know if you have read any of my other posts where I introduced myself.
I used to own a shop called LincolnMotorsport where I specialized in Lincoln MarkVIIIs.
I have done way more trannies on my back than I care to think about right now, and yes it IS easier on a lift.But the only essentials of doing it in your garage or driveway is 4 large jackstands that can be bought at any auto zone or Sams club and a good floor jack.(That and no fear of hard work) LOL.
I applaud you for doing your own work.Words cannot describe the feeling of accomplishment you get when you tackle a job like this yourself.And I dont want anyone to dissuade people from working on their own cars.
Again, If you run into any problems feel free to ask, I'd be more then willing to help.
