Greddy EVO 2 Mpegs!
![Talking](https://www.clublexus.com/forums/images/icons/icon10.gif)
Thanks goes to Banchi105 for hosting the mpegs! the links are below:
http://www.ntbstudios.com/drg/MOV01245.MPG
http://www.ntbstudios.com/drg/MOV01246.MPG
Hope this helps with your decision making for those of you considering upgrading exhaust.
EV ftw!!!
That sounds incredible!!!!
![Big Thumb Up](https://www.clublexus.com/forums/images/smilies/biggthumpup.gif)
EV ftw!!!
How much did you pay for this exhaust system? If you would rather not post the price on the forum please PM me. Thanks!
Originally posted by jucee187
That does sound wicked.!!!. but remember his car is supercharged.. im sure it sounds different on a non supercharged GS..
whats the diff between the PE and EVO?...
"Greddy EVO 2 Exhaust System. NOW IN FULL STAINLESS STEEL ! Inherent in its name, the EVO2 cat-back exhaust system is a huge step forward. In addition to the GReddy straight-through technology, offset tip design and large piping diameters of the original EVO, the EVO2 is now offered in full stainless steel providing improved looks, durability and corrosion resistance while maintaining the best qualities of the original such as fitment, sound and performance.
GReddy EVO Exhaust System with a similar flow rate and muffler can to the PE systems, the EVO's new offset tip design improves road clearance in most models. Another benefit is the appearance of a small muffler on the car, but still allows for excellent sound suppression. The newly added embossed GReddy logos on both the SUS tip and can will set the system apart from the rest."
HAMEED, The lowest ive seen this exhaust go for is $819USD
I just remembered reading somewhere that this particular cat-back is not recommended for non-aspirated engines. Just thought I'd mentioned this to you guys before any of you consider running out and purchasing. You may want to contact Greddy and get the full scoop firsthand.
Hope this helps.
Hope this helps.
