engine fan always going off
You mean jus the radiator fan? Yeah, that's normal. When it gets cool enough it turns the fan off, and when it gets hot enough, it turns it back on. The fan turning on at idle is much more common than when you're driving down the road... especially if you're on the highway.
Matter o' fact, if your radiator fan stays on all the time, it's a bad thing. It means your engine is either running very hot all the time, or your thermostat is stuck open/gone bad and needs to be replaced. That or your coolant and cooling lines are in bad condition)
exclusive matchup
pyr8
12-08-17 05:13 PM
